First post, by Geladin
Hi @all,
I have a problem. I have a DOS Software that doesn't run in DOS Mode or similar under Windows 98. But the Device should keep Windows 98 (because of other software).
Now I created a conf with mapping a drive and start the software automatically. Works fine.
But there is one problem. Even when I set fullscreen=true or start Dosbox with Parameter -fullscreen DosBOX refuse to start in Fullscreen Mode.
I also tried to set resoultion manually. Or set the output from Surface to Overlay/OpenGL etc.
Everything I tried, it won't start in Fullscreenmode.
Graphics Card: S3 SuperSavage/IXC with 16MB VRAM on Pentium III 1133MHz with 512MB RAM.
Thanks in advance and sorry for my "not so good" english
