First post, by edasx
hi there, i am trying to get running Sensible World Of Soccer CD on Windows XP SP1. I am using launchpad, i have downloaded the latest VDMSound and the VDMSound.2.0.4.update1 and installed. I am trying to achieve the two joystick support in this game. the problem is:
first joystick is calibrated fine...
second joystick is couldn't be calibrated
a) when i put the joystick to the upper left corner it shows good values (upper left)
b) in the center it shows good values (centre)
c) in lower right it shows bad values (almost same as upper left)
d) if i move the first joystick to the lower right, the second shows correct values when moved to lower right
i played a lot with the coordmin, coordmax, it's always same... any ideas both joysticks are connected to the creative labs soundblaster live value gameport via quadswitch as-a4 device, i also tried standard y-cable... the problems seems not to appear in the device test in the windows xp controllers control panel, but only in the game (installation program & ...) - i supplied the config program that fails at this url http://bubaq.wz.cz/2joys.zip [select config then control then 2 joysticks...]
any suggestions welcome (better drivers for gameport, some leak in vdm, bad controllers?)
