First post, by Bama_38
I am having problems getting Commander Keen Goodbye Galaxy to run with VDMSound. It ran the first time with the basic configuration, then I closed the program and tried it again and it just sticks on initializing. Then I have to manually close the program down. I have tried changing some setting in properties but I guess I just don't know what does what because it always does the same thing. Any help would be appreciated. I also have Commander Keen Aliens Ate My Babysitter but I haven't tried it yet although I expect it is very similar.
Reply 1 of 2, by Reckless
Any reason you're not using DOSBox for this classic game?! From memory I think the side scrolling feature of the game doesn't really like modern video cards and I'm sure it works better under DOSBox!
Reply 2 of 2, by Guest
I'll check into DosBox I haven't ever tried it. Thanks for the suggestion!
