Project 386-16SX
First post, by candle_86
So I helped a friend out and got my hands on a 386 sx which I've built up for the 4 hours.
Spec's
INTEL 80386SX-16
2048MB ram
TRIDENT TVGA8900C 256K
Soundblaster 32 with 2mb SIMM expansion
Super I/O card unknown brand
Intel 10BaseT nic
510MB cf
1.44 and 1.2 floppy drives
Dvd-rom connected to sb32 ide port
The attachment 20200605_154534.jpg is no longer available
If anyone can help identify the board I'd appreciate it aswell
The attachment 20200605_150903.jpg is no longer available
Reply 1 of 14, by appiah4
It should be roughly on par with a 286-12 in terms of 16-bit speed. You get to run 386 code with it though, so even better. Run the AWE32 in MT-32 mode and enjoy some Monkey Island 😀
I can't identify the motherboard but that looks like an AT chipset/motherboard to me.
Reply 2 of 14, by rmay635703
2gig of ram is pretty impressive looks like an Old Pc Partner board.
Will have to Peruse TH99
Reply 3 of 14, by candle_86
Sorry 2mb
Reply 4 of 14, by candle_86
so i have two banks of GM71C1000-80, giving me a total of 2mb, if i wanted to upgrade the board would would i look for.
Reply 5 of 14, by Caluser2000
candle_86 wrote on 2020-06-06, 16:45:
I don't see any 30 pin sipp or simm connectors on the mobo so you may reqire a 16 bit isa memory card of some sort. It'd make a good Dos/GeoWorks system as is though.
Reply 6 of 14, by candle_86
Nope no sipp or simms, I'll look into 16bit expansion cards.
Reply 7 of 14, by candle_86
For this I was thinking the external header is a 6v so would sticking two coil cells together do the trick, it has no internal battery it was always external.
Reply 8 of 14, by Anonymous Coward
GM71C1000-80 is 1mbit memory is it not? Given the number of chips installed, shouldn't you have 4MB?
Reply 9 of 14, by candle_86
Memory was fixed, and my gotek just came in, time to get it all working
Reply 10 of 14, by candle_86
Landmark compares the system to a 23mhz AT and PC player got 1.2 in slow, fast won't start, Doom averages to 8.7 fps. Alot if tests won't run because my Trident 8900c appearantly isn't vesa compliant
Reply 11 of 14, by appiah4
8.7fps in doom on a 386SX-16? Were you running it at matchbox size? Sounds impossible for default view size settings.
Reply 12 of 14, by candle_86
appiah4 wrote on 2020-07-21, 08:47:
Phil's did bench Doom slow, small view window, lowest settings.
Reply 13 of 14, by appiah4
candle_86 wrote on 2020-07-21, 13:12:
I wish people would stop using this, it's so utterly meaningless..
Reply 14 of 14, by candle_86
appiah4 wrote on 2020-07-21, 13:17:
I disagree it's informative
