First post, by kingcake
It won't boot. No post no beep no nothing. I tried all the usual troubleshooting then I discovered a dreaded varta nimh battery that leaked. Is this mobo a goner?
Reply 1 of 4, by Caluser2000
It could well be recoverable after removing the battery, carefully cleaning the affected area with vinegar then ipa and maybe some demineralised water.
Reply 2 of 4, by derSammler
No way. Even in this tiny section, you have dozens of traces to rebuild. And he did not even show the whole mainboard.
145.1 KiB
As sad as it is, but that board is done.
Reply 3 of 4, by Windows9566
derSammler wrote on 2020-06-11, 07:16:
Time to recycle it sadly, RIP Packard Bell. those batteries are timebombs.
R5 5600X, 32 GB RAM, RTX 3060 TI, Win11
P3 600, 256 MB RAM, nVidia Riva TNT2 M64, SB Vibra 16S, Win98
PMMX 200, 128 MB RAM, S3 Virge DX, Yamaha YMF719, Win95
486DX2 66, 32 MB RAM, Trident TGUI9440, ESS ES688F, DOS
Reply 4 of 4, by IBMFan
Even if it could be repaired it would look like shit. You have to remove every affected chip, rewire at least 30 traces and put SMDs back.
In the end it would look like this but with 20 more wires and you wouldn't want it anywhere near you.
Let it go.
