First post, by RussellM
Hello there, first post here and apologies if it’s incorrectly placed, I did try.
I have an old Compaq Presario 425 that I was quite happily running with Windows 3.1. For some reason after installing drivers for a Zip drive it didn’t boot back the same way it left. It seems rather odd when I go into the F10 system setup and under fixed disk drives there are 65 options, some of which read as things like 17mb/503mb/33mb/117mb, it seems pretty random and some exceed the capacity of the drive. I don’t know I’m a complete novice so maybe that’s normal partitioning?
Anyway, I had believed I formatted the disk and installed DOS and 3.1 again, it worked until I rebooted and I lost it. Same drove selection shows. However now when I try to boot the drives it will show as either DRIVE 0 error or missing operating system. That’s ok I thought, I have the original dos boot disks, no, it gets as far as “starting ms-dos...” and just stalls there, no opportunity to enter commands, nothing.
The machine is acknowledging the drive and I have tried loading others (80gb so I imagine it wouldn’t work anyway) so I would put it down to disk failure but I find the idea of it failing in that period of time far too coincidental.
Any advice on how to get an operating system loaded again would be greatly appreciated! I just bought an old ISA soundcard and have games just waiting to go 🙁
Reply 1 of 19, by pii_legacy
Are you positive your hard drive size settings are correct? It won't run unless it's exactly correct, and i'm guessing that got changed from what it was.
Reply 2 of 19, by RussellM
pii_legacy wrote on 2020-06-15, 04:45:
To be totally honest, I’m unsure. I seem to only have the option to select one of these existing drives from the BIOS or define new drive, there doesn’t seem to be much option in the setup
Reply 3 of 19, by Pierre32
It might not be too wild a thought that the disk has died on you after some intenstive writing. Happened to me a couple of days ago!
Anyway, run this from a floppy to get the drive geometry for BIOS: https://archive.org/details/whatide
And here are the factory image files if you want them: https://archive.org/details/compaq425433filesmsdos62
Reply 4 of 19, by RussellM
Pierre32 wrote on 2020-06-15, 05:03:
I’ll give this a try as soon as, thank you!
Reply 5 of 19, by RussellM
Unfortunately no luck. Installed an IBM 170mb, managed to get to the old install of windows on it, as well as boot into DOS. Formatted the HD from there, installed a new copy of Windows, got all the way to reboot after install and now we are back to not being able to boot anything from disk or floppy. All physical connections are fine and it is capable of booting both from HD and Floppy, it just won’t and I can’t figure why ..
So these are my options presented to me at bios, disk seems correctly identified and floppy boot enabled.
The attachment 0B82E918-9099-43EC-A627-2C987CD97229.jpeg is no longer available
The attachment 871FE570-9E83-42D5-A18B-369B9273CD53.jpeg is no longer available
And then this is the error message displayed
The attachment 6C16B278-E4AE-4A96-8A71-018E392D2CB1.jpeg is no longer available
And if I boot without a floppy in the drive
The attachment 9CA98D54-0743-4D4F-8634-1DD3090A3FCC.jpeg is no longer available
And then of course if I boot with a boot disk in the drive I’m hanging on this forever
The attachment ADE40563-4736-4815-8CF4-C8B5D7CDBA14.jpeg is no longer available
Reply 6 of 19, by Cobra42898
if there isnt an auto setting that is correct for the drive, then look at the physical drive itself. they usually have the CHS info on them, and you may need to manually enter that in the bios.
Searching for Epson Actiontower 3000 486 PC.
Reply 7 of 19, by RussellM
Cobra42898 wrote on 2020-06-15, 17:34:
Thanks, although I have already tried defining custom drive type with both drives tried so far, cylinders, heads, sectors exactly as on the drive.
I don’t suppose precomp or max ecc need to be specified?
I may give out a postcode for finding a Compaq Presario 425 in a random skip. Got windows installed again, installed some drivers, tried installing Iomega zip drivers, had to reboot, forgot all drivers the first time, second time forgot how to boot to windows or dos
Reply 8 of 19, by Pierre32
Have a look at this thread: Compaq Presario 433, my 486 pure DOS machine
OP says he had difficulty getting a different HDD installed, possibly due to some weird proprietary config the Compaq does. But others say they've done it. It might be a lead for further investigation. I'm a 425 owner but I'm still running the stock HDD, so I haven't had to think about this issue yet.
FYI your pics are pretty tiny, so I can't really see what's going on!
Reply 9 of 19, by RussellM
Pierre32 wrote on 2020-06-15, 21:00:
Thanks for that, I had a quick read through the thread and it’s helpful, hopefully. I’ve got a bit of trouble getting a BIOS flash onto readable media at the moment, a million floppy drives and none writing.
However I have noticed that after any real length of time the BIOS totally forgets time, date and I’m assuming the defined drives, boot order etc too. Despite it managing to boot into Windows after 20 years of inactivity when I took ownership.
So I’ve ordered a new soldering iron and the CMOS battery is getting replaced, I’m not sure it’s going to help seeing as even when I do get into booting MS-DOS it just hangs with no input available.
I’ll update this thread if I do find a solution just in case anyone else finds the same issue but I have to be honest with my limited ability and the seemingly random behaviour of the machine I don’t think I’ll be booting into an OS twice in a row.
Reply 10 of 19, by evasive
how is that ZIP disk connected?
Reply 12 of 19, by Pierre32
RussellM wrote on 2020-06-15, 22:23:
Thanks for that, I had a quick read through the thread and it’s helpful, hopefully. I’ve got a bit of trouble getting a BIOS fla […]
Cool. Good opportunity to replace the soldered battery with an offboard type. Look forward to hearing how you go.
Reply 13 of 19, by RussellM
Out of interest, for the sake of a novice, how would I go about writing those factory image files to the HDD considering the size ?
Reply 14 of 19, by Pierre32
That's a challenge. Any way to get the Zip drive working without having to install drivers to C:? You would of course need a way to write to it from another computer too.
Personally I use a parallel port CF reader, but that's an obscure solution. For any other machine I'd say grab a cheap internal IDE-CF adapter, but that's not straightforward in these machines (as there are no spare IDE or molex connectors). I have one of these in mine too, but it required some cabling modifications.
Other options include parallel port CD-ROM, ISA ethernet card, or connecting the HDD to a modern PC with USB-IDE adapter.
Reply 15 of 19, by RussellM
Pierre32 wrote on 2020-06-15, 23:17:
I have a huge stack of old network cards so most likely option would be the ISA Ethernet card, I guess my only concern then is will it be possible without any command prompt available from the recepient machine, I guess so, doubt Compaq were paying the hours for booting each system!
Edit: no the Zip drive isn’t going to work, unfortunately the stage I’m at I can’t even select a drive let alone run drivers but I did notice it wasn’t working prior without driver install
(I should learn to think before typing): I have lots of empty IDE external drive cases, that ought to be worth a shot.
Reply 16 of 19, by RussellM
SOLUTION
This is for the benefit of anyone else that may come across this thread whilst searching for the same issue.
This does not resolve the BIOS issue which will require the CMOS battery to be replaced.
Stuck at “Starting MS-DOS...”
-reboot into F10 system setup
-set custom drive definition to exactly as written on physical hard dyrive or in specifications for your drive
-Make find, borrow or steal DOS 5.O disk and insert into A:
-Run DOS install and open into shell
-Search C: for any windows folders, delete from C: with deltree windows or deltree [folder name]
-Reboot and make sure you can get back into shell, then insert Win 3.1 Disk & run setup
I had previously tried formatting the disk and removing windows and it just didn’t work, the ONLY way I could get myself back into Windows was by doing this exact sequence and using MS-DOS 5. 0
Thank you kindly for replies and help, it’s very much appreciated.
Reply 17 of 19, by Pierre32
Good work sorting it out. So if I'm reading it correctly, the key to this was using a fresh DOS 5.0 boot disk instead of the original system boot disk? And said original disk is the Compaq OEM disk?
Reply 18 of 19, by RussellM
The system did originally have the Compaq OEM installed, however after forgetting itself (my presumed CMOS issue) it wouldn’t boot back into the windows installation, even if you specify very clearly the drive parameters and also the directory location in DOS and that was only after re-installing DOS on a newly defined drive (of course as stated physically on the drive).
For some reason or other my issue seemed to be with DOS 6.22. It may have just been that there were multiple windows directories on the drive by the time I had finished (3.11/3.1).
So yes a completely fresh install of 5.0 and retail 3.1 on top of that, checking and double checking the drive was defined correctly and all windows directories were removed and it worked first time and consistently. As I mentioned it definitely has an issue with the CMOS battery, which I imagine is a simple replace (not so simple as I’m sure you know on this board) since it forgets the system settings entirely when power is unplugged.
Reply 19 of 19, by Jo22
This Compaq seems to have 2 ISA slots, which it seems are usually equipped with a network card and a soundcard..
http://eintr.net/systems/compaq/presario433/index.html
Wouldn't it the best to just use XTIDE Universal BIOS then ?
This would avoid the need to ever enter Compaq BIOS again and would allow for pretty big fixed disk drives also. 😀
