First post, by esbardu
I have an old AMD K6 or K6-2 233. It had a heatsink glued and when removing it almost all the letters dissapeared.
I would say that it's a K6-233 and that some years ago I had tested it in the same board where I had a P-233 MXX simply interchanging the CPUs but I'm not sure.
I have a board with a P-166 MMX where I could test it or an Asus P5A with a K6-2 533. But ... I'm afraid that testing it incorrectly might damage the boards.
Is it a K6 233 or a K6-2 233?
    201.47 KiB
Reply 2 of 7, by quicknick
^This. Also the fact that it was marked with paint rather than engraved (but I guess there are exceptions). Anyway, biggest difference is the VCore (3.2V for the K6 vs. 2.2V for the K6-2), so set the board for the lower value and see if it boots; if it doesn't it's probably a plain K6.
Reply 3 of 7, by mkarcher
esbardu wrote on 2020-06-18, 20:02:
The important question is not "is a K6 or a K6-2". For 233MHz processors, the important question is: Is it a 3.2V (28Watt) or a 2.2V (13.5W) CPU? There are both K6 and K6-2 233MHz processors running at 2.2V, and being a K6 or a K6-2 doesn't matter for setting up the mainboard.
There is a clue in your picture: on the ceramic case, below the heat spreader, there is a number printed in the lower left. From what I can see on the image, the only package number that matches a widely available K6 processor and is consistent with the pieces of digits on your photo is 25910. This is a 3.2V 233MHz K6 processor.
Reply 4 of 7, by esbardu
You are all amazing! Thanks!
I will test it in the P166, PCChips M520 (probably not the best brand). I had a Pentium 233 MMX on this board and I remembered that I had to chose another multiplier to get 3,5x, will need to check. I will try as soon as I can take the PC home, at home right now I have only a P3 and a K6-2 and I don't want to test it in the K6-2.
I also have an Octek RHINO 6VX .
Let's hope I don't damage anything 😀. Voltage in the two boards will be 3,3v.
Reply 5 of 7, by esbardu
It's working on a Rhino 6X, it shows as K5 233Mhz. Still need to test it.
I have directly swapped it with a Pentium 100 66x1,5. For the K6 233 1,5 multiplier works as 3,5.
I will try to update BIOS. I have too many retro projects at the same time 😀..
    243.98 KiB
    415.83 KiB
    610.98 KiB
    371.02 KiB
Reply 7 of 7, by esbardu
chrismeyer6 wrote on 2020-06-19, 13:59:
I'm wondering if it's miss reporting cause I thought that the K5 topped out at 133.
Sure, it is a K6. I guess that in terms of performance there won't be any issues but still need to test. I will also update the BIOS during the weekend.
