First post, by crazyzed
I just bought my first Roland gear. It is what would appear to be an old version, it doesn’t have a head phone connector. When checking the ROM version though, I found that it is version 2.00. I thought 1.07 was the highest version for the old unit?
Would this unit be considered a new version?
For compatibility, what’s the downside of 2.00 compared to 1.07?
I see there are 1.07 ROMs out for sale. Are they placed in a socket being easily changed, or does it require soldering? Could this unit even be downgraded below 2.00?
Reply 2 of 10, by BloodyCactus
maybe you have a version right on the transition period. but sounds odd to me. pics would be great!
Reply 3 of 10, by crazyzed
Unfortunately I don’t have the tools or know how to dump the roms 😒
I’ll try to get some pictures this weekend.
Reply 4 of 10, by crazyzed
I opened it up and got some pictures.
Serial: Z940799
Model: DM-32N-7
Just checked and it has the demo songs. From what I understand only the new version has those?
The attachment 9102DD7B-BD58-4805-BFA8-31E440F48A88.jpeg is no longer available
The attachment CDC5999E-E425-4E4B-8D2D-429EBCEBCEE7.jpeg is no longer available
The attachment E291543D-C4CA-4B92-8E0E-0D12FF10615C.jpeg is no longer available
The attachment 67A4D89F-E190-42C0-B493-CE2A5B84E87F.jpeg is no longer available
So what do you make of this?
Reply 5 of 10, by BloodyCactus
well the space is there on the pcb for the jack. its definitely a 'new' mt32, not 'old' mt32. for whatever reason they did not solder the jack on.
Reply 6 of 10, by yawetaG
BloodyCactus wrote on 2020-06-26, 19:55:
The casing itself is the 'old' version, hence no jack.
Reply 7 of 10, by the Goat
Never seen that before. ROM version 2 is for MT-32 "new". Which is what that circuit board is. But it is in an MT-32 "old" case and the headphone jack is not installed.
Reply 8 of 10, by BloodyCactus
yawetaG wrote on 2020-06-27, 09:53:
right. probably right in the transition period and used up old stock.
Reply 9 of 10, by jesolo
So, in theory, you could just drill a hole in the rear and solder on a jack? You would then have a complete MT-32 "new" with its headphone jack.
Reply 10 of 10, by yawetaG
jesolo wrote on 2020-06-27, 19:26:
So, in theory, you could just drill.a hole in the rear and solder on a jack? You would then have a complete MT-32 "new" with its headphone jack.
Quite likely.
