First post, by ykot
I have just got a compact AT case powered by this beautiful working board. However, I am quite surprised and unfamiliar with this layout. It seems to be using Cyrix Cx486DLC as CPU and Cyrix FasMath CX-83D87-33 GP as co-processor. In the BIOS it also mentions 128Kb of cache.
Am I correct to think that this is actually a 386 motherboard using 486 processor?
I have immediately unsoldered the barrel battery, which already started to leak acid on one side, and see there is a 4-pin jumper labeled "EXT_BAT", with a jumper in the middle pins of 2-3. What would be the meaning of these pins?
There is also another jumper on right side labeled "JP4" - would be interesting to know what it controls.
By the way, this thing is so small - probably smaller than a Mini-ITX factor. Under one of ISA slots it says "G W386/486 MAIN BOARD".
Edit: updated photo after desoldering barrel battery and cleanup, and attached BIOS dump.
    BIOS-2020-06-29.zip
    42.28 KiB
    43 downloads
    BIOS dump from the motherboard
    635.42 KiB
    Photo after desoldering barrel battery and cleanup
Reply 1 of 10, by Deksor
I think I've found it : http://www.uncreativelabs.de/th99/m/U-Z/32922.htm
The ext bat connector is to connect an EXTernal BATtery ^^
If it start, can you show us pictures of the POST screen or even better, send us a dump of your BIOS ?
Reply 2 of 10, by Anonymous Coward
Nice 486DLC. It has some pretty unusual OEM markings.
Reply 3 of 10, by Horun
Yes it is a very odd OEM label, no luck in searches. Wonder who TI built those for, or did they (OEM) just remove TI or Cyrix label and add their own logo.... curious !
Reply 4 of 10, by cyclone3d
Looked up CDCOM International Inc. and it looks like they were an importer and reseller.
Seems they had a shipment of VGA cards seized in 1996 by US customs due to the mfg having a counterfeit MS logo on them:
https://books.google.com/books?id=Q7xrzP4cit4 … %20inc.&f=false
https://www.corporationwiki.com/Florida/Miami … nc-4370769.aspx
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 5 of 10, by ykot
Thank you for identifying this motherboard, I really appreciate it.
I have edited my initial post with BIOS dump and updated the photo. I am attaching here BIOS startup screen and some benchmarks. I couldn't run CCT386 as it would crash with "exp overflow", similarly HWINFO would crash with "exp overflow" during FPU benchmark. SpeedSys takes too long to benchmark CPU so I'll run it later. Curiously, NSSI identified FPU as "Internal Emulator"?
By the way, on the aforementioned web page with the jumper information, chipset is described as "unidentified", but looking at some chips it seems to be UMC.
Edit: it looks like these benchmarks were performed with NPU disabled by JP7 jumper, enabling it eliminates CCT386 and HWINFO crashes and improves NSSI - FPU benchmark, I'll upload those later...
    309.88 KiB
    355.59 KiB
    NSSI - CPU benchmark
    217.54 KiB
    Norton Utilities - CPU benchmark
    257.66 KiB
    BIOS startup screen
Reply 6 of 10, by evasive
Amptron DX-5800 aka PCChips M3** (previously thought to be the M326 but that has a different layout and chipset).
Here's another (Amptron/PCChips) CDCOM offering in another thread:
M396F motherboard
Reply 8 of 10, by ykot
Thanks a lot! This has been running great so far, very fast and stable. I have ordered an AMD 386 DX/40 along with its co-processor (which already arrived) to try with this motherboard and see how it performs in comparison to Cyrix.
