ESS Audiodrive ES1868F and MIDI
First post, by Lostdotfish
Hi all.
I'm in the process of cobbling together a Pentium 200 MMX build for DOS/W98 gaming. I'm trying to get the MIDI port on this card working with no luck initially. I haven't installed any software for it and I've purely initialized it using SET BLASTER in my autoexec.bat.
Digital audio is working fine. I added P330 to my SET BLASTER command hoping that would be all I needed... no joy. Could anyone advise? I'm trying to get the ESS card to drive a Roland SC-55 and using Doom shareware as my test program.
Thanks
Reply 1 of 42, by appiah4
A P200MMX with an ES1868 driving an MT32 and a wavetable card is my default system these days. Please post your autoexec.bat and config.sys files as well as driver package you are using.
Off the top of my mind:
Have you tried SoftMPU. exe?
Are you sure your MIDI cable works? Have you tried a wavetable daughterboard insted?
Have you checked your mixer settings?
If you have ACPI running at IRQ 2/9 that may be conflicting with the MPU401 port?
Are you sure you wired the setup rigght? (Midi out to Midi in)
Are you sure your SC works fine?
Reply 2 of 42, by Lostdotfish
appiah4 wrote on 2020-07-04, 13:35:
A P200MMX with an ES1868 driving an MT32 and a wavetable card is my default system these days. Please post your autoexec.bat and […]
I'm not using any drivers at the moment - just using SET BLASTER
SET DOSDIR=C:\FDOS
!LASTDRIVE=D
!BUFFERS=30
!FILES=40
DOS=HIGH
DOS=UMB
DOSDATA=UMB
DEVICE=C:\FDOS\BIN\JEMMEX.EXE EMX X=TEST I=TEST min=32768 max=32768 sb split
SHELLHIGH=C:\FDOS\BIN\COMMAND.COM C:\FDOS\BIN /E:1024 /P=C:\AUTOEXEC.BAT
@ECHO OFF
SET DOSDIR=C:\FDOS
SET PATH=%dosdir%\BIN
SET BLASTER=A220 I5 D1 P330 T4
SET DIRCMD=/P /OGN /Y
SET COPYCMD=/-Y
LH CTMOUSE
:END
SET AUTOFILE=%0
SET CFGFILE=C:\FDCONFIG.SYS
alias reboot=fdapm warmboot
alias reset=fdisk /reboot
alias halt=fdapm poweroff
alias shutdown=fdapm poweroff
alias cfg=edit %cfgfile%
alias auto=edit %0
REM cd tools
REM cd lbx
REM call launch
cd \
This is a pretty random install of FreeDOS that I just had lying around so it's quite possible not setup very well.
I'm certain the SC-55 works, I've tested it on my main PC on SCUMMVM using a USB MIDI cable.
I'm not certain the Gameport to MIDI cable works as it is brand new but no reason to suspect it.
I'm fairly sure I just haven't got the right software and settings
Reply 3 of 42, by darry
The ES1868F is plug and play and is typically auto-configured by BIOS or a initilization utility . In your case the BIOS is doing the initilization and may not be doing it properly/completely for the MPU-401 part. Using the ESSCFG.EXE util would put that doubt to rest .
How have you determined it's MPU-401 is actually configured at port 330h ? Again, using ESSCFG.EXE would allow you to confirm this or actually set it to 330h if it is not already .
EDIT: The set blaster variable is used to tell software how your card is configured . It does not do any actual configuration or initialization.
Reply 4 of 42, by Oetker
Does Windows detect the MPU-401? Then you can use device manager to check at which port it's mapped.
But really you should just download the DOS drivers and use ESSCFG and ESSVOL to troubleshoot.
Reply 5 of 42, by Lostdotfish
I've installed the DOS drivers now and verified the port is set correctly. Still no midi coming out.
I've tried Softmpu too. It detects SB Pro compatible card and MPU on 330. It then says port trap failed submit a bug report...
I'm putting this down for a bit. I think I'll pop a clean 6.22 on it later and try from scratch.
Reply 6 of 42, by darry
Lostdotfish wrote on 2020-07-04, 14:10:
You must use Microsoft's EMM386.EXE for the Softmpu port mapping to work (QEMM386 might work too, not sure)
Your problem could be due to the the joystick to MIDI cable . There are a lot of crappyones floating around on a certain auction site .
Reply 7 of 42, by appiah4
I am 90% sure it is a bad cable.
Reply 9 of 42, by Lostdotfish
Ok just did a clean DOS 6.22 install.
Installed the ESS drivers
Ran SoftMPU and it detects and runs on port 330
Still no midi hitting the SC-55
Reply 10 of 42, by appiah4
Lostdotfish wrote on 2020-07-04, 15:41:
appiah4 wrote on 2020-07-04, 14:52:
Any easy way to prove or rule this out?
If you have a waveblaster card of some sort try it on the header; if that works it's a) the DB15 connector b) the cable. Regarding the former, try spraying some contact cleaner into the DB15 gameport connector maybe? Regarding the latter, maybe you could monitor the MIDI-Out (Pin 12) pin of the DB15 Gameport with an oscilloscope to see if there is a signal there when you try to play something back?
Reply 11 of 42, by Oetker
Lostdotfish wrote on 2020-07-04, 15:56:
Ok just did a clean DOS 6.22 install. […]
Post a picture of your MIDI cable.
SoftMPU isn't needed for an SC-55.
Reply 12 of 42, by Lostdotfish
Oetker wrote on 2020-07-04, 16:41:
It's one of these (from that auction site...)
It looks well made enough. I'll pop it open and check to see if it's sound or needs reworking.
Reply 13 of 42, by darry
Lostdotfish wrote on 2020-07-04, 17:16:
Pretty sure you won't find anything but wire inside (which would explain the lack of function). I had the same issue when looking for a spare . Finally found a cheap new old stock one that worked .
In your case, fixing your existing can likely be done by following the schematic in this thread .
"Quality" gameport to midi cable availability and testing
Reply 14 of 42, by Lostdotfish
darry wrote on 2020-07-04, 17:31:
Pretty sure you won't find anything but wire inside (which would explain the lack of function). I had the same issue when lookin […]
Yup nothing but wire. At £15, the seller can have this junk back...
Is there a reliable source for good cables at all?
Reply 15 of 42, by darry
Lostdotfish wrote on 2020-07-04, 18:38:
Other than fixing or making one, the only "trick" that I have to suggest is to try to find one with the connector shells made of moulded plastic . This increases your chance of getting one that was made back in the day when this was current tech (and likely well made). This is not surefire, as there may exist crappy ones with moulded shells too, but this is such a low volume item that I doubt anybody would bother making crappy new adapters with a custom moulded shell.
Reply 16 of 42, by Oetker
I bought a crappy one with moulded plastic shells. It contained a PCB but completely wrong resistors. Adding proper resistors to yours should work, you don't need an opto coupler for output and a buffer isn't necessary either.
Reply 17 of 42, by Oetker
https://www.serdashop.com/DB15MIDI
Reply 18 of 42, by darry
Oetker wrote on 2020-07-04, 18:57:
I stand corrected . One should never underestimate the bottom feeders .
Oetker, was yours branded ?
Reply 19 of 42, by darry
Oetker wrote on 2020-07-04, 19:00:
That's cool, I thought they were out of stock .
Thanks !
