First post, by primalphoenix
Ive managed to install dos on a newer pc but i cant get the audio drivers to work. my card is the one stated in the title, and ive managed to find some sort of driver for it, but i cant use it because it needs to be in bus 0, and i dont have any motherboards that have a pci slot in bus 0, only agp, pcie etc. I'm wondering if theres any way to make it work in a different bus, or if i can use the ac 97 onboard audio.
Mobo: asus p5kpl-cm (there seems to be two audio connectors, one regular hda/ac97 and the older type, that is on the top of the card, and the pc speaker, that sounds terrible, apparently)
