First post, by tomexplodes
Title. I found nircmd at one point, which lets me change res via a batch file, the problem is I'd do something like
nircmd setdisplay 800x600x16
mageslay.exe
nircmd setdisplay 800x600x32
and it would WORK but it did all three of those things in rapid succession, so it skipped the whining but went right back to 32bit color.
If there's no way to do it, that's totally fine, but I figured it couldn't hurt to check. Thanks!
- Tom
1.) MS-DOS 6.22, Pentium-S 90mhz, 32mb RAM, S3 Trio64, Vibra 16
2.) Windows 98 SE, AMD Athlon XP 3000+ 2.1ghz, 512mb RAM, Geforce 4 TI 4200 128mb, Sound Blaster Live! Value
Reply 2 of 3, by Falcosoft
tomexplodes wrote on 2020-07-08, 18:39:
Title. I found nircmd at one point, which lets me change res via a batch file, the problem is I'd do something like […]
mageslay.exe
- Tom
You should use 'start' command with /w[ait] option to execute your program. This way your batch file (and thus 'nircmd setdisplay 800x600x32') will wait for your game to exit.
start /w mageslay.exe
Website, Youtube
VST Midi Driver Midi Mapper
x86 microarchitecture benchmark (MandelX)
Reply 3 of 3, by tomexplodes
Falcosoft wrote on 2020-07-08, 20:40:
You should use 'start' command with /w[ait] option to execute your program. This way your batch file (and thus 'nircmd setdispla […]
mageslay.exe
- Tom
That's perfect! Thank you so much!
Er, once I took out the Xs anyway, haha. Thanks again!
