First post, by tomexplodes
- Member
I believe I found it, here: https://www.elhvb.com/webhq/models/pcchips/m520.htm
I'll attach the pictures I took for verification. I just want to know if I can wire up my turbo button to cut the mhz when it's pressed. I have a pentium 120 in it currently, I'd like to be able to cut it to 66 or 60 mhz. If this can be done, please tell me how. If it cannot, that is fine too. Thank you for your time and all your help.
1.) MS-DOS 6.22, Pentium-S 90mhz, 32mb RAM, S3 Trio64, Vibra 16
2.) Windows 98 SE, AMD Athlon XP 3000+ 2.1ghz, 512mb RAM, Geforce 4 TI 4200 128mb, Sound Blaster Live! Value
