First post, by PlaneVuki
Hello,
My hardware specs are: pentium-100, 8mb ram, vga, pc speaker, etc...
My software specs are: ms-dos from 5.0 to 6.22, that's it, no extra drivers or anything.
How can I make ms-dos be loaded in upper memory?
What should my config.sys look like ?
I tried a few combinations I found on internet with no luck, it either took ~64k my conventional or extended or high memory.
notice: I don't want to load it to extended or high memory, only to UMA (above 640kb, below 1mb)
Thanks much in advance.
Reply 6 of 6, by Jo22
PlaneVuki wrote on 2020-07-18, 16:25:
What should my config.sys look like ? […]
Hi, what does it look like now?
There are lots of possibilities for tweaking.
Also, since my knowledge of Blood is little,
maybe the problem is a different one?
Issues with DPMI, for example. Or EMM386 has compatibility issues?
I don't know. Maybe some memory manager (Qemm) can do its magic here.
