First post, by brettp11
Hi,
I’m trying to mount my motherboard to my case. I’ve noticed that two of the mounting holes on the motherboard do NOT have a metal ring around them like the others do (see pictures). These holes are needed to mount it securely and line up perfectly with the case. Can I screw a metal MB screw in these holes or do I risk shorting the board? Do I need a plastic insulating washer for these holes?
Thank you!
