First post, by spacesaver
MIDI enthusiast here. I have an Audigy 2 ZS (Gateway OEM SB0355) and Win98SE. I cannot run Creative Soundfont manager. I get "SoundFont Manager initialization failed" . Diagnostics also don't work, but I do have sound.
I suspect this could be an incomplete installation. I couldn't install directly from the Audigy 2 CD because of the OEM model, so I manually extracted the VXD drivers and installed them using Windows device manager. I couldn't find any .sf2 files installed. According to another post, the default sound font should be C:\Windows\System\CT4MGM.SF2. I found it on the CD, but don't know how it's installed
It would be a shame if Sound fonts aren't supported on OEM models 🙁 Audigy 2 OEM users, are you able to switch sound fonts and what did you have to install? What is the default sound font?
Reply 1 of 4, by Joseph_Joestar
I made a guide for using the ZS on Win98/DOS, but I'm not sure if that will work for OEM cards.
If it doesn't, you may need to hunt down the manufacturer's custom drivers.
Reply 2 of 4, by schmatzler
The diagnostics tool and the soundfont manager don't detect the card when the drivers are manually installed, so that's normal behaviour, unfortunately.
I've faced the same problem a while ago with my non-OEM Audigy 2 and I also don't have a solution for that. 🙁
Reply 3 of 4, by spacesaver
I can load Sound fonts now! The trick was running CTZAPXX to install the drivers instead of manually using Device Manager. That also installs the 2MB sound font to C:\Windows\system and creates some MIDI interfaces. In control panel -> Multimedia -> MIDI, there are now 4 interfaces instead of 2. Thanks a lot for making the guide.
Reply 4 of 4, by Joseph_Joestar
Cheers, I'm glad everything worked out for you!
