First post, by DosFreak
For those not aware of the work being done on winraid and MDL then this thread is for you.
https://forums.mydigitallife.net/threads/driv … hardware.81607/
*Login required
ACPI 2.0+ - Patched drivers to workaround STOP 0xA5 errors related to new ACPI standards […]
ACPI.SYS 6666 (from outerspace :p)
ACPI.SYS 5048 (from Vista beta)
Memory related
WinXPPAE v2 - Patches kernel and hal files to enable PAE (Physical Address Extension)
USB3 / XHCI
Kernel Mode Driver Framework 1.11 by MOV AX, 0xDEAD - Unofficial standalone installer based on the Security Update KB2864202 for Windows 8. Needed for USB3 / XHCI driver stack.
USB3/XHCI (generic) driver by MOV AX, 0xDEAD - Backported from Windows 8, requires the Kernel Mode Driver Framework 1.11 to be installed first. Includes UASP (USB Attached SCSI Protocol) support. Multilingual INF file.
Deprecated:
AMDXHCI 145 v3 with PAE patch by MOV AX, 0xDEAD - Driver patched to support Intel USB3 controllers
AMDXHCI 276 with PAE patch by MOV AX, 0xDEAD - Driver patched to support Intel USB3 controllers (based on Windows 7 driver)
Storage support (AHCI / RAID / NVMe)
AHCI (generic) driver by MOV AX, 0xDEAD - Backported from Windows 8, requires storport.sys (backported from Windows 7) and storpor8.sys from Extender, both included.
NVMe (generic) driver - Backported Windows 7 driver, requires storport.sys (also backported from Windows 7, included).
Samsung NVMe (generic) driver 3.3.0.2003 - Backported Windows 7 driver, requires storport.sys (backported from Windows 7, included).
For Intel:
RSTe 4.7.0.1117 - XP x86 (updated) - Backported Windows 7 driver, requires storport.sys (backported from Windows 7, included).
For AMD:
AHCI driver 1.2.1.402 - Windows 7 driver, requires storport.sys (backported from Windows 7), included
Make your games work offline
Reply 1 of 9, by Barley
Sorry for the necro post, but the links to the files on MDL are long dead and I did not have any luck with Wayback Machine or intense Google Fu. I read that maybe I could extract these files from Windows XP Integral Edition but the download has failed 3 times tonight. You wouldn't happen to have copies of these files, would you? I'm looking for these ones:
Memory related
USB3 / XHCI
TIA
Reply 2 of 9, by LSS10999
Barley wrote on 2025-06-12, 02:49:
Sorry for the necro post, but the links to the files on MDL are long dead and I did not have any luck with Wayback Machine or in […]
Memory related
USB3 / XHCI
TIA
Those drivers/utilites can be found in most recent versions of WinXPIE Patch Integrator. However, considering this forum's rules, you'll have to search it by yourself.
EDIT: So you're already aware of it. Maybe you can find some standalone Patch Integrator releases (fixes made after formal WinXPIE releases) in the comment area though it can be an effort going through all the posts there.
Reply 3 of 9, by Barley
Got 'em! Thank you!
Reply 4 of 9, by Barley
LSS10999 wrote on 2025-06-12, 04:06:
I need some help. I have the following folders from the latest Patch Integrator:
Microsoft USB3.x xHCI driver v2.2
Kernel-Mode Driver Framework 1.11
Miscellaneous
I was able to follow the directions to put some files from the Miscellaneous folder into the system32 folder, but am at a loss on how to install the Kernel-Mode Driver Framework 1.11 and actual USB 3 driver(s).
Help?
Reply 5 of 9, by Barley
I'm fiddling around with nlite and see that I can add the driver to my ISO. I guess I'll try that, but I'm worried about skipping all the instructions in the various README's.
Reply 6 of 9, by Barley
Last update. I fiddled with the Patch Integrator and added the USB 3 driver to the ISO I use. I will test it out...
...but, is that really the only way to install the usb 3 drivers? I was hoping I could just install them to an existing Windows XP installation.
Reply 7 of 9, by LSS10999
Barley wrote on 2025-06-12, 21:54:
The Patch Integrator does a good deal of things, including installing a custom certificate and signing the drivers with it, so Windows will not complain about those newly added drivers.
Yes it's theoretically possible to use the Patch Integrator with a different ISO than WinXPIE but you may need to make some modifications.
Reply 9 of 9, by Jo22
wierd_w wrote on 2025-06-13, 03:57:
There was that UEFI loadable CSM awhile back.
New project called CSMWrap, a new legacy OS boot solution for UEFI-only systems lacking a built-in CSM
WinXP needs a CSM, as does Win7, even when it is using UEFI. It might be worthwhile to see if it works for this purpose.
I think Windows XP is humble enough to make it work.
In the past, XP ran on SeaBIOS as well as Apple's Bootcamp BIOS.
That BIOS was a very minimal BIOS that ran on a Mac's EFI firmware.
