First post, by appleg33k85
Good Morning, this is my first post though I have been a long time reader of this forum so thanks in advance for help on this issue!
I recently picked up an IBM Clone that has a 386 motherboard in it. The computer powers on fine but comes up with a keyboard error. The battery leaked and is in the keyboard connection area so I'm surmising that this is the cause of the problem. I haven't yet done a full cleanup of the board because I want to see if this board is salvageable before going on. I've attached some photos of the error along with photos of the board. It looks like some of the traces may be damaged on the back? The only information on the model of the board is the DE-M E108357 on the back.
The attachment IMG_20200723_063624 Update.jpg is no longer available
The attachment IMG_20200723_063649.jpg is no longer available
The attachment IMG_20200723_063634.jpg is no longer available
The attachment IMG_20200718_141038.jpg is no longer available
Reply 1 of 4, by kalohimal
Yeah should be no problem as the corrosion looks localized. Just clean up the battery juice and corrosion with vinegar and fix up any broken traces. There is a portion beneath the ISA slot and RAM slots that looks affected though, so it is good if you could desolder some of them and clean below.
Slow down your CPU with CPUSPD for DOS retro gaming.
Reply 2 of 4, by appleg33k85
kalohimal wrote on 2020-07-23, 13:33:
Thanks for the reply, I'll do a cleanup and see where we are!
Reply 3 of 4, by Miphee
Check continuity between the keyboard connector pins and the keyboard controller pins (not in order):
1. - NC
2. - pin 5
3. - pin 39
4. - pin 20
5. - pin 1
Beware that there are different types of configurations but most 386 boards I've checked used this scheme. Check the remaining trace paths too before soldering anything.
Reply 4 of 4, by Intel486dx33
I soaked an entire motherboard for 2 days in vinegar and it worked. It cleaned up all the corrosion but also destroyed allot of other capacitors. I don’t know if these capacitors were bad anyways but it cleaned up all the corrosion very good.
So I dont recommend you soak the motherboard for more than a few hours. Also scrub with a small brush like a tooth brush.
