Reply 1 of 17, by Shagittarius
- Oldbie
It appears the jumper is configured for autoswitching in your photo, so according to my manual all the switches should be set to on.
The only thing those switches control is manual settings for the monitor used for multiple monitor setups. You should just close all the Dip switches and keep the jumper the way you have it set and you should be fine.
Reply 2 of 17, by muon
Shagittarius wrote on 2020-07-23, 18:20:It appears the jumper is configured for autoswitching in your photo, so according to my manual all the switches should be set to on.
Hi Shagittarius !!
Thanks for the info. Could you take a picture from that page to see the differents options (monomonitor/multiple monitors=?
Thanks in advance
Reply 3 of 17, by muon
Reply 4 of 17, by Shagittarius
- Oldbie
muon wrote on 2020-07-23, 19:25:
4 is open in your picture. they should all be 'Down'. I can't take a picture right now so the manual scan will have to wait until later.
Reply 5 of 17, by Horun
- l33t++
Shagittarius wrote on 2020-07-23, 19:59:4 is open in your picture. they should all be 'Down'. I can't take a picture right now so the manual scan will have to wait until later.
Please do as I also have one and all are "up" or "on" on my card but that should be same as what you say depending how the switch is oriented ? Thanks !
Reply 6 of 17, by Shagittarius
- Oldbie
Here is the relevant 4 pages for the non-auto config settings, it doesn't have a picture for auto-config but just says if the auto-config jumper is enabled, close all the dip-switches to turn them on.
EDIT: Sorry, this is not the same card I should have realized. My card is the PEGA1A. Anyways attached is the relevant section for the PEGA1A board.
Reply 7 of 17, by maxtherabbit
- l33t
Shagittarius wrote on 2020-07-24, 15:08:Here is the relevant 4 pages for the non-auto config settings, it doesn't have a picture for auto-config but just says if the auto-config jumper is enabled, close all the dip-switches to turn them on.
do you have the rest of the manual by chance?
Reply 8 of 17, by Shagittarius
- Oldbie
I do, I will try to scan the whole manual cover to cover this weekend and post it here.
Reply 9 of 17, by maxtherabbit
- l33t
Shagittarius wrote on 2020-07-24, 15:54:I do, I will try to scan the whole manual cover to cover this weekend and post it here.
that's amazing thank you
Reply 10 of 17, by muon
maxtherabbit wrote on 2020-07-24, 15:56:Shagittarius wrote on 2020-07-24, 15:54:I do, I will try to scan the whole manual cover to cover this weekend and post it here.
+1
Thanks a lot, Shagittarius
Reply 11 of 17, by Shagittarius
- Oldbie
Sorry guys, got busy, will try to remember to get to this this weekend again.
Reply 12 of 17, by Shagittarius
- Oldbie
Here ya go, it's not perfect but is all legible.
https://www.dropbox.com/s/wi7u23uvyqz127i/Par … Manual.pdf?dl=0
Reply 13 of 17, by maxtherabbit
- l33t
Yes!
Reply 14 of 17, by Horun
- l33t++
Shagittarius wrote on 2020-08-01, 18:12:Here ya go, it's not perfect but is all legible.
https://www.dropbox.com/s/ehpi6545rthqd6x/Par … Manual.pdf?dl=0
Great and Thank you ! My card is the WD AutoSwitch EGA 480 (256k PEGA2) and having the manual is so much better. The switch settings are same as my crappy little text sheet. One thing I found interesting is my card has a silkscreened EEPROM (not a UV EPROM like in pictures at vgamuseum.info. The print on it says: PARADISE 22030-C1201-C400, 1289 31. The only other picture of PEGA with silkscreened ROM is at VCFed but it is a PEGA1 based.
Reply 15 of 17, by Jinxter
- Member
Link is not working. Could you please fix?
Check out my YouTube channel: Retro Erik https://www.youtube.com/c/RetroErik
My collection: https://retro.hageseter.com
X: https://x.com/Retro_Erik
Reply 16 of 17, by Shagittarius
- Oldbie
Jinxter wrote on 2022-02-09, 19:15:Shagittarius wrote on 2020-08-01, 18:12:Here ya go, it's not perfect but is all legible.
https://www.dropbox.com/s/ehpi6545rthqd6x/Par … Manual.pdf?dl=0Link is not working. Could you please fix?
Sorry try here:
Reply 17 of 17, by Jinxter
- Member
Shagittarius wrote on 2022-02-09, 20:53:Jinxter wrote on 2022-02-09, 19:15:Shagittarius wrote on 2020-08-01, 18:12:Here ya go, it's not perfect but is all legible.
Sorry try here:
Thank you.
