First post, by Robhalfordfan
i like to share my build for my windows 98se build and took a long while to build and find/try out different parts and games to see what works best for me for now and might be upgrades/downgrades or changes in the future
specs are :-
Motherboard - MSI MS-6528lE
PSU - Seasonic M12 II EVO Bronze 520W (Will be downgrading at some point)
Processor - Intel Pentium 4A - 1.6 ghz (Northwood)
Ram - 512 MB (Offtek SD-RAM PC-133) (1x 256MB + 2x 128MB)
Graphic Card - Albatron GeForce 4 TI 4200 Turbo - 64MB
Sound Card - Sound Blaster Live 5.1 Platinum
Ethernet Card - TP-Link TF-3200 - 10/100m
Firewire Card - Pluscom 4 Port Firewire Controller PCI Adapter
Drives
- 1x 3.5 Floppy (720KB - 1.44MB)
- 1x 3.5 Iomega Zip 250 ATAPI (100MB - 250MB)
- 1x Aopen COM5232/AAH PRO Combo CD-RW/DVD-Rom
- 1x Maxtor Diamondmax Plus 9 6Y080L0 - 80GB
- 1x Maxtor DiamondMax Plus 9 6Y120L0 - 120GB
I/O Ports
- 4x USB ports (2x on Mobo + 2x on Case)
- 2x PS/2 Port
- 2x DB-9 M Serial
- 1x DB-25 F Parallel
- 2x VGA (Mobo - DISABLED) (GPU - ENABLED)
- 1x DVI-D (GPU - NOT USED)
- 2x Gameport (Mobo - DISABLED) (Soundcard - ENABLED)
- 1x On-Board Audio (DISABLED)
- 1x Ethernet Port
- 3x 6 pin Firewire Port (2x External) (1x Internal)
- 1x 4 pin Firewire Port
Extras
- Sound Blaster Live 5.1 Platinum - 5.25 I/O Bay
- 2x 80mm Case Fan
- PS/2 Mouse + Keyboard
Operating System
- Windows 98se (with Plus Installed)
UPDATE
Unfortunately the mobo died ages ago and but managed save the rest of parts and will posting a new build post for it soon even though it will more of less be the same as this one
    151.57 KiB
    387.85 KiB
    1.97 MiB
    1.05 MiB
    1.78 MiB
Reply 2 of 8, by buckeye
Nice rig. I'm curious how much faster it is than a tualatin 1.4ghz based system running win98.
Reply 3 of 8, by Robhalfordfan
Sago7 wrote on 2020-07-29, 14:32:
Wow, that's a beautiful build.
What games do you tried?
thank you 😀
generally anything from 97/98-01/02
quake 3
return to castle wolftenstein
kiss - psycho circus - the nightmare child (runs fine but need to restart pc after exiting game as there's a bug with directx with playing anything else afterwards or with dxdiag and it didn't matter what gpu or directx version i used) (doesn't do it in win xp - must be win98 bug)
empire earth 1
solder of fortune 1
GTA 3
Blair Witch Trilogy
prob loads more but go to ones are normally quake 3, return to castle wolfenstein and mafia 1 (which runs fines on low to med settings (800x600) - i run it on my xp build to max out (1024x768))
Reply 4 of 8, by Robhalfordfan
buckeye wrote on 2020-07-29, 15:28:
thank you 😀
this might tell you this different with cpu - i think
http://www.cpu-world.com/Compare/125/In ... 7256).html
i have no idea, with win98
this cpu is high on 98 and good enough on very early xp (pre sp1 - maybe sp2) and would be low/slow on sp3 xp
i choose it so i don't need to replace the psu so often as it run on 12v rail instead of the 5v rail and also the Willamette p4, were nae as good (compare to p3 of the day) and also i could use a stock intel cooler from a higher clocked cpu with no issues 😁
Reply 6 of 8, by Robhalfordfan
vellu wrote on 2020-07-30, 09:25:
socket 478 cooler mounting bracket gives me nightmares. Have you thought about replacing it with new cooler as well? Best Byte seems to have ones made of steel.
the cooler is originally from a p4 2.8ghz with hyperthreading (got a bit too warm and a tad hot while heavy gaming) and thought that since this p4 is more or less half that speed with no hyperthreading that it should work and it does and doesn't actually get that warm or hot
Reply 7 of 8, by buckeye
Robhalfordfan wrote on 2020-07-29, 15:36:
thank you :) […]
thank you 😀
this cpu is high on 98 and good enough on very early xp (pre sp1 - maybe sp2) and would be low/slow on sp3 xp but
I'd be interesting to see the differences in gaming performance. Looks like another project for my "bucket list".
Nice CRT by the way, I can never find any in good shape locally......yet.
Reply 8 of 8, by Robhalfordfan
buckeye wrote on 2020-07-30, 19:36:
thank you :) […]
thank you 😀
be interesting to see if there is a major different and thank you, nice way to play old retro games (pre HD and widescreen)
