First post, by kataniel
Hello folks,
I recently started Dune2 on my 486 equipped with a Shuttle HOT-235 Soundcard (Opti82C930, SB Pro compatible) and a DB50XG attached to it. Unfortunately, the midi music is way to loud so the digital speech and effects are hardly noticable during gamplay. If I remove the DB50XG, the digital effects are roughly twice as loud as with the DB50XG attached and clearly noticable. Dune2 ignores the volume setting in OPTI's mixer control tool SNDINIT.EXE /V, so I don't have the option to use these mixer settings to adjust midi vs digital effects ratio. In addition, Dune2 doesn't offer volume control (as far as I know).
I already tried a second HOT-235 - same problem.
I also tried the patched SETUP.EXE for Dune2 1.07 to set different sound devices for music (DB50XG) and digital effects (SB Pro), but still the same: The music is way to loud.
I don't know what to try next. Any ideas?
Dell Optiplex GL5100 | Pentium 100 | S3 Trio64V+ 2MB onboard | 64MB EDO | WDAC2850 | FX810 | OPTi 82C929 + NEC XR385
Dell Optiplex 466LE | am486 DX5 133 | CL-GD5429 1MB onboard | 8MB FPM | WDAC2540 | FX400 | HOT-235 + DB50XG
Reply 1 of 6, by badmojo
The DB50XG is powerfully loud but your problem sounds more than that - do other games sound OK with this setup? DOOM messes with the mixer to, are the levels OK with that game?
Or do you have a different sound card to try?
Reply 2 of 6, by kataniel
Yes, the same problem exists in Doom BUT there is separate volume control for FM and Speech, so I can set music to 40% and digital effects to 100% to make it nearly equivalent.
Privateer respects the settings from SNDINIT.EXE where I also set FM to 40% and digital effects to 100%.
Observation: When I start Privateer, speech and music are set according to settings in SNDINIT.exe. VOLTSR.EXE (Opti's TSR tool for in-game volume control) works in Privateer. If I start Dune2 afterwards, SNDINIT settings are ignored (music very loud, effects silent) and VOLTSR doesn't work (also not in DOOM). If I start Privateer again after Dune2, FM is way louder than during first start. I suppose, Dune2 sets FM to 100%. Normal volume settings (music: 40, effects: 100) have to be restored via SNDINIT.EXE /B after finishing Dune2 to restore correct ratio.
Unfortunately, I don't have other soundcards to test. Only the HOT-235 spare card.
Reply 3 of 6, by badmojo
And you're 100% sure you're using the right version of the mixer software? I had a PAS16 acting strangely once because I was using the wrong version, so it might be worth having a hunt around for other versions.
Reply 4 of 6, by Joseph_Joestar
Try these drivers and see if that makes any difference.
They were downloaded from Shuttle's website.
Reply 5 of 6, by kataniel
@badmojo, @Joseph_Joestar Thanks for your replies.
These are the drivers that I'm using with my two HOT-235 cards. It seems that they have a problem with sound volume when a wavetable board is attached. I wouldn't say that the card is defective as the problem persists in two machines with two different HOT-235 cards.
I (temporarily) used a dual card setup for testing: The HOT-235 with wavetable board in conjunction with a CT2890 (Soundblaster 16 Vibra with real OPL3 chip) that is connected from line out to HOT-235's line in. This setup works without problems (after I tuned the input/output levels of both cards the right way). But I did not like the fact that I had to initialize/configure two cards at startup and use two different programs.
My new (and hopefully final) setup is an Opti 82C929 based card ("Pro Multimedia" with Multi CD, Wavetable header and OPL clone chip) that does not have the problems (also using the 82C929 drivers from vogons). All problems are gone. Sound volume is the same in all games and FM is not overly loud. Very nice!
In the next few days, I'll get a Shuttle HOT-233 (with real YMF-262!) to put into the second machine, so I can hope the problem is solved then for both machines.
Reply 6 of 6, by badmojo
Good to hear! It amazes me how wonky the default levels of some ISA era sound cards are - when you find a card that sounds right without any mixer fiddling it feels like a major win.
