First post, by Solplay
- Newbie
For Socket 478 only
Northwood Mobile Pentium 4(-M) CPUs - No MSRs involved, uses pin GHI# to switch multipliers
Prescott Mobile Pentium 4 CPUs - MSRs are involved, doesn't seem to use pins to switch multipliers (most likely to work)
This is a guide for enabling SpeedStep on motherboards that don't support it, which may or may not work as SpeedStep requires BIOS support, chipset support, and CPU support. Try it at your own risk, I have gotten BSoDs before.
Steps
1) Download Read & Write Everything v1.7 from this link: http://rweverything.com/downloads/RwPortableV1.7.zip (requires XP SP3 x86 or 2000 SP4 with blackwingcat's extended kernel)
2) Extract it out from the zip, and place it anywhere that you prefer.
3) Run Rw.exe, and then click on the icon that looks like a flipped PGA478 CPU. It has a text labeled as 'MSR' on it.
4) A window with the name of 'CPU MSR Registers' should pop-up, once that loads, click on the 'User' tab.
5) Click on the 'User' icon/button, and then copy the text below to its text box (not the text box found on the left side of the 'Add' button). Click on the 'Done' button once you have entered them in.
IA32_PERF_CTL=0x199
IA32_MISC_ENABLE=0x1A0
6) Double-click on the newly created register called 'IA32_MISC_ENABLE', now you should be able to see 64 bits shown in a small pop-up window. Do not click on any of the registers yet.
7) Double-click on the number below register 16, it should be then flipped to '1'. This forces SpeedStep to be enabled, but be aware that this may cause a BSoD. Make sure that you have nothing important running at this moment. Once you have done that, click on 'Done'.
8) If it doesn't trigger a BSoD, congratulations. You have just enabled SpeedStep, assuming register 16 didn't reset itself back to '0'.
My last request if you have made it this far: did you notice anything in the IA32_PERF_CTL register? Are there any numbers in it? If there are any, what are they?
SpeedStep/Turbo Boost drivers
Turbo Boost Technology Driver v1.2.0.1002 - Vista/7
https://dl.dell.com/chipset/R275031.exe
Turbo Boost Technology Driver v1.0.1.1002 - XP/Vista/7
https://download.lenovo.com/ibmdl/pub/pc/pccb … es/6ips01ww.exe
SpeedStep Applet v3.4 - 2K
https://dl.dell.com/utility/INTEL_SPEEDSTEP_A17_R190149.exe
SpeedStep Applet v3.3 - 2K
https://dl.dell.com/utility/R150537.exe
SpeedStep Applet v3.2 - 2K
http://download.lenovo.com/ibmdl/pub/pc/pccbb … es/79sue3us.exe
SpeedStep Applet v3.10 - 98/NT4/2000
http://download.lenovo.com/ibmdl/pub/pc/pccbb … es/1ysue1us.exe
SpeedStep Applet v2.30 - 98/Me/NT4/2K
http://download.lenovo.com/ibmdl/pub/pc/pccbb … es/spdstp1g.exe
SpeedStep Applet v2.10 - 98/Me/2K
http://download.lenovo.com/ibmdl/pub/pc/pccbb … es/spstep2k.exe
SpeedStep Applet v1.30a - 95/NT4
http://download.lenovo.com/ibmdl/pub/pc/pccbb … es/spstepnt.exe
SpeedStep Applet v1.10 - 95/98/Me/NT4/2K
http://download.lenovo.com/ibmdl/pub/pc/pccbb … es/utspstep.exe
Intel
[!] = Caution
[?] = Datasheet + product brief
* = Alphanumeric code
OEM suffixes: R (Dell), H (HP), P (HPE), C (Fujitsu), L (Lenovo)
Some SSDs may include two random alphanumeric characters at the end of its model code, sometimes it's an OEM suffix or it's just blank.
1.8-inch form factor
X18-M SSD [SATA-2.6 | MicroSATA | 5mm tall | 3.3V]
• SSDSA1M160G2
• SSDSA1M080G2
[?] https://download.intel.com/newsroom/kits/ssd/ … m_DataSheet.pdf | https://download.intel.com/newsroom/kits/ssd/ … roductBrief.pdf
SSD 320 [SATA-2.6 | MicroSATA | 5mm tall | 3.3V]
• SSDSA1NW300G3
• SSDSA1NW160G3
• SSDSA1NW080G3
[?] https://www.intel.com/content/dam/www/public/ … ecification.pdf | https://www.millennium.ca/pdf/Intel_SSD_320_S … oduct_Brief.pdf
SSD DC S3500 [SATA-3.0 | MicroSATA | 5mm tall | 3.3V]
• SSDSC1NB800G4
• SSDSC1NB400G4
• SSDSC1NB240G4
• SSDSC1NB080G4
[?] https://www.intel.com/content/dam/www/public/ … -s3500-spec.pdf | https://www.mouser.com/datasheet/2/612/ssd-dc … rief-769409.pdf
SSD DC S3610 [SATA-3.0 | MicroSATA | 5mm tall | 3.3V]
• SSDSC1BG800G4
• SSDSC1BG400G4
• SSDSC1BG200G4
[?] https://www.intel.com/content/dam/www/public/ … -s3610-spec.pdf | https://www.prodimex.ch/intel-ssd-dc-s3610-series-2.5"-sata-6-gb_s-480-gb-ssdsc2bx480g401-103210_en.pdf
SSD DC S3700 [SATA-3.0 | MicroSATA | 5mm tall | 3.3V]
• SSDSC1NA400G3
• SSDSC1NA200G3
[?] https://www.intel.com/content/dam/www/public/ … -s3700-spec.pdf | https://tiscom.ru/sites/default/files/additio … s3700-brief.pdf
2.5-inch form factor
X25-V SSD [SATA-2.6 | StandardSATA | 9.5mm tall | 5V]
• SSDSA2M040G2
[?] https://mpt-internal.uni-hohenheim.de/lib/exe … productline.pdf | https://www.comx-computers.co.za/download/pdf … 2MP040G2R5p.pdf
X25-M SSD [SATA-2.6 | StandardSATA | 7 & 9.5mm tall | 5V]
• SSDSA2M160G2
• SSDSA2M080G2
• SSDSA2J080G2
[!] 'J' models are 9.5mm tall
X25-E SSD [SATA-2.6 | StandardSATA | 7mm tall | 5V]
• SSDSA2SH064G1
• SSDSA2SH032G1
[?] https://download.intel.com/newsroom/kits/ssd/ … E_DataSheet.pdf | https://persy.com/docs/extreme-ssd.pdf
SSD 311 [SATA-2.6 | StandardSATA | 9.5mm tall | 5V]
• SSDSA2VP020G2
[?] https://archive.techplayboy.com/images/review … tion_325035.pdf | https://store.ee.co.uk/content/uni2/documenta … 7jhy/325502.pdf
SSD 313 [SATA-2.6 | StandardSATA | 9.5mm tall | 5V]
• SSDSA2UP024G3H
• SSDSA2UP020G3H
[!] HP was the only OEM that made use of this model; a standard non-OEM variant doesn't exist
[?] https://pcper.com/wp-content/uploads/2012/04/ … ecification.pdf | https://www.millennium.ca/pdf/Intel_SSD_313_S … oduct_Brief.pdf
SSD 320 [SATA-2.6 | StandardSATA | 7 & 9.5mm tall | 5V]
• SSDSA2CW600G3
• SSDSA2CW300G3
• SSDSA2CW160G3
• SSDSA2CW120G3
• SSDSA2CW080G3
• SSDSA2CT040G3
[!] 'T' models are 7mm tall
SSD 330 [SATA-3.0 | StandardSATA | 9.5mm tall | 5V]
• SSDSC2CT240A3
• SSDSC2CT180A3
• SSDSC2CT120A3
• SSDSC2CT060A3
[?] https://www.intel.com/content/dam/www/public/ … ecification.pdf | https://download.intel.com/newsroom/kits/ssd/ … roductBrief.pdf
SSD 335 [SATA-3.0 | StandardSATA | 9.5mm tall | 5V]
• SSDSC2CT240A4
• SSDSC2CT180A4
• SSDSC2CT080A4
[?] https://www.intel.com/content/dam/www/public/ … ecification.pdf | https://www.intel.com.au/content/dam/www/publ … d-335-brief.pdf
SSD 510 [SATA-3.0 | StandardSATA | 9.5mm tall | 5V]
• SSDSC2MH250A2
• SSDSC2MH120A2
[?] https://www.scribd.com/document/51165091/Inte … t-Specification | https://www.thomas-krenn.com/en/wiki/Intel_51 … SDs_Information
SSD 520 [SATA-3.0 | StandardSATA | 7 & 9.5mm tall | 5V]
• SSDSC2CW480A3
• SSDSC2CW240A3
• SSDSC2BW240A3
• SSDSC2CW180A3
• SSDSC2BW180A3
• SSDSC2CW120A3
• SSDSC2BW120A3
• SSDSC2CW060A3
[!] 'B' models are 7mm tall
[?] https://www.intel.com/content/dam/www/public/ … ecification.pdf | https://www.millennium.ca/pdf/Intel_SSD_520_S … oduct_Brief.pdf
SSD 530 [SATA-3.0 | StandardSATA | 7mm tall | 5V]
• SSDSC2BW480A4
• SSDSC2BW360A4
• SSDSC2BW240A4
• SSDSC2BW180A4
• SSDSC2BW120A4
• SSDSC2BW080A4
[?] https://www.intel.com/content/dam/www/public/ … ecification.pdf | https://www.mouser.com/datasheet/2/612/ssd-53 … rief-368532.pdf
SSD 535 [SATA-3.2 | StandardSATA | 7mm tall | 5V]
• SSDSC2BW480H6
• SSDSC2BW360H6
• SSDSC2BW240H6
• SSDSC2BW180H6
• SSDSC2BW120H6
• SSDSC2BW056H6
[?] https://www.intel.com/content/dam/www/public/ … sd-535-spec.pdf | https://www.mouser.com/datasheet/2/612/ssd-53 … rief-769408.pdf
SSD 540s [SATA-3.2 | StandardSATA | 7mm tall | 5V]
• SSDSC2KW010X6
• SSDSC2KW480H6
• SSDSC2KW360H6
• SSDSC2KW240H6
• SSDSC2KW180H6
• SSDSC2KW120H6
[?] https://www.intel.com/content/dam/www/public/ … series-spec.pdf | https://www.intel.com/content/dam/www/public/ … eries-brief.pdf
SSD 545s [SATA-3.2 | StandardSATA | 7mm tall | 5V]
• SSDSC2KW512G8
• SSDSC2KW256G8
• SSDSC2KW128G8
[?] https://www.bhphotovideo.com/lit_files/397146.pdf | https://www.intel.com/content/dam/www/public/ … -545s-brief.pdf
SSD 710 [SATA-2.6 | StandardSATA | 7mm tall | 5V]
• SSDSA2BZ300G3
• SSDSA2BZ200G3
• SSDSA2BZ100G3
[?] https://www.intel.co.kr/content/dam/www/publi … ecification.pdf | https://www.millennium.ca/pdf/Intel_SSD_710_S … oduct_Brief.pdf
SSD 730 [SATA-3.0 | StandardSATA | 7mm tall | 5/12V]
• SSDSC2BP480G4
• SSDSC2BP240G4
[!] does not require 12V and 5V rails to be present, either voltage will work
[?] https://www.intel.com/content/dam/www/public/ … series-spec.pdf | https://www.also.com/ec/cms5/media/img/5410_1 … eries-brief.pdf
SSD Pro 1500 [SATA-3.0 | StandardSATA | 7mm tall | 5V]
• SSDSC2BF480A4
• SSDSC2BF360A4
• SSDSC2BF240A4
• SSDSC2BF180A4
• SSDSC2BF120A4
• SSDSC2BF080A4
[?] https://www.intel.com/content/dam/www/public/ … ecification.pdf | https://media.dustin.eu/media/d20000100227119 … es-document.pdf
SSD Pro 2500 [SATA-3.2 | StandardSATA | 7mm tall | 5V]
• SSDSC2BF480H5
• SSDSC2BF360H5
• SSDSC2BF240H5
• SSDSC2BF180H5
• SSDSC2BF120H5
[?] https://www.intel.com/content/dam/www/public/ … ecification.pdf | https://www.mouser.com/datasheet/2/612/ssd-pr … rief-780492.pdf
SSD Pro 5400s [SATA-3.2 | StandardSATA | 7mm tall | 5V]
• SSDSC2KF010X6
• SSDSC2KF480H6
• SSDSC2KF360H6
• SSDSC2KF240H6
• SSDSC2KF180H6
• SSDSC2KF120H6
[?] https://www.comx-computers.co.za/download/int … iN120-5400S.pdf | http://8thgen.pillarglobalsolutionsinc.swcont … oduct_Brief.pdf
SSD Pro 5450s [SATA-3.2 | StandardSATA | 7mm tall | 5V]
• SSDSC2KF010T8
• SSDSC2KF512G8
• SSDSC2KF256G8
[?] no datasheet available, use the 545s datasheet | https://www.zones.com/images/pdf/intel-ssd-pr … oduct-brief.pdf
SSD E 5100s [SATA-3.2 | StandardSATA | 7mm tall | 5V]
• SSDSC2KR256G8
• SSDSC2KR128G8
• SSDSC2KR064G8
SSD E 5400s [SATA-3.2 | StandardSATA | 7mm tall | 5V]
• SSDSC2KR180H6
• SSDSC2KR120H6
• SSDSC2KR080H6
[?] https://wfcache.advantech.com/www/certified-p … e_datasheet.pdf | no product brief available
SSD E 7000s [SATA-3.2 | StandardSATA | 7mm tall | 5V]
• SSDSC2BR960G7
• SSDSC2BR480G7
• SSDSC2BR240G7
• SSDSC2BR150G7
[?] no datasheet available | https://www.mouser.com/datasheet/2/612/e7000s … ief-1110551.pdf
SSD DC S3100 [SATA-3.0 | StandardSATA | 7mm tall | 5V]
• SSDSC2KI010X6
• SSDSC2KI480H6
• SSDSC2KI240H6
• SSDSC2KI180H6
[?] https://gzhls.at/blob/ldb/d/e/3/5/933fc545727 … 0b8fdcdeab4.pdf | https://www.prodimex.ch/intel-ssd-dc-s3100-sa … 1-101280_en.pdf
SSD DC S3110 [SATA-3.0 | StandardSATA | 7mm tall | 5V]
• SSDSC2KI512G8
• SSDSC2KI256G8
• SSDSC2KI128G8
[?] no datasheet available, use the 545s datasheet | no product brief available, use the 545s product brief or https://cdrdv2-public.intel.com/796064/PCN116615-00.pdf
SSD DC S3500 [SATA-3.0 | StandardSATA | 7mm tall | 5/12V]
• SSDSC2BB016T4
• SSDSC2BB012T4
• SSDSC2BB800G4
• SSDSC2BB600G4
• SSDSC2BB480G4
• SSDSC2BB300G4
• SSDSC2BB240G4
• SSDSC2BB160G4
• SSDSC2BB120G4
• SSDSC2BB080G4
[!] does not require 12V and 5V rails to be present, either voltage will work. 1.2TB and 1.6TB models are the same, however they will use both 12V and 5V rails if they are present. 12V-only operation is not supported for 1.2TB and 1.6TB models.
[?] https://www.intel.com/content/dam/www/public/ … -1-6tb-spec.pdf (for 1.2TB and 1.6TB models only)
SSD DC S3510 [SATA-3.0 | StandardSATA | 7mm tall | 5/5+12V]
• SSDSC2BB016T6
• SSDSC2BB012T6
• SSDSC2BB800G6
• SSDSC2BB480G6
• SSDSC2BB240G6
• SSDSC2BB120G6
• SSDSC2BB080G6
[!] supports 5V-only or 5+12V operation, 12V-only operation is not supported
[?] https://www.intel.com/content/dam/www/public/ … -s3510-spec.pdf | https://www.mouser.com/datasheet/2/612/ssd-dc … rief-780477.pdf
SSD DC S3520 [SATA-3.0 | StandardSATA | 7mm tall | 5/5+12V]
• SSDSC2BB016T7(O)
• SSDSC2BB012T7(O)
• SSDSC2BB960G7(O)
• SSDSC2BB800G7(O)
• SSDSC2BB480G7(O)
• SSDSC2BB240G7(O)
• SSDSC2BB150G7(O)
[!] supports 5V-only or 5+12V operation, 12V-only operation is not supported. models with an 'O' suffix are branded as an SSD DC S3320
[?] https://wfcache.advantech.com/www/certified-p … 2_datasheet.pdf | https://i.crn.com/sites/default/files/ckfinde … oduct_brief.pdf
SSD DC S3610 [SATA-3.0 | StandardSATA | 7mm tall | 5/5+12V]
• SSDSC2BX016T4
• SSDSC2BX012T4
• SSDSC2BX800G4
• SSDSC2BX480G4
• SSDSC2BX400G4
• SSDSC2BX200G4
• SSDSC2BX100G4
SSD DC S3700 [SATA-3.0 | StandardSATA | 7mm tall | 5/12V]
• SSDSC2BA800G3
• SSDSC2BA400G3
• SSDSC2BA200G3
• SSDSC2BA100G3
SSD DC S3710 [SATA-3.0 | StandardSATA | 7mm tall | 5/5+12V]
• SSDSC2BA012T4
• SSDSC2BA800G4
• SSDSC2BA400G4
• SSDSC2BA200G4
[?] https://www.intel.com/content/dam/www/public/ … -s3710-spec.pdf | https://www.mouser.com/datasheet/2/612/ssd-dc … rief-780477.pdf
SSD DC S4500 [SATA-3.0 | StandardSATA | 7mm tall | 5/5+12V]
• SSDSC2KB076T7
• SSDSC2KB038T7
• SSDSC2KB019T7
• SSDSC2KB960G7
• SSDSC2KB480G7
• SSDSC2KB240G7
[?] https://advdownload.advantech.com/productfile/PIS/96FD25-S19T-INB3/Product - Datasheet/96FD25-S19T-INB3_datasheet20171107133938.pdf | https://m2m-enterprise.com/wp-content/uploads … s4600-brief.pdf
SSD D3-S4510 [SATA-3.0 | StandardSATA | 7mm tall | 5/5+12V]
• SSDSC2KB076T8
• SSDSC2KB038T8
• SSDSC2KB019T8
• SSDSC2KB960G8
• SSDSC2KB480G8
• SSDSC2KB240G8
[?] https://lenovopress.lenovo.com/lp0924.pdf | https://www.solidigm.com/content/dam/solidigm … oduct-brief.pdf
SSD DC S4600 [SATA-3.0 | StandardSATA | 7mm tall | 5/5+12V]
• SSDSC2KG038T7
• SSDSC2KG019T7
• SSDSC2KG960G7
• SSDSC2KG480G7
• SSDSC2KG240G7
SSD D3 S4610 [SATA-3.0 | StandardSATA | 7mm tall | 5/5+12V]
• SSDSC2KG076T8
• SSDSC2KG038T8
• SSDSC2KG019T8
• SSDSC2KG960G8
• SSDSC2KG480G8
• SSDSC2KG240G8
[?] https://lenovopress.lenovo.com/lp0925-intel-s … am-sata-6gb-ssd | https://www.solidigm.com/content/dam/solidigm … oduct-brief.pdf
Mini-PCI Express form factor
Turbo Memory 1.0 [PCIE 1.0a | Robson | Type F1 | 3.3V]
• NVCPEMWR001G1
• NVCPEMW0512M1
[?] no datasheet available | http://szarka.ssgg.sk/Vyuka/Prednaska-9/Turbomem/316979.pdf
Turbo Memory 2.0 [PCIE 1.1 | Robson | Type H1 | 3.3V]
• NVCPEHWR004G2
• NVCPEHWR002G2
SSD 310 [SATA-2.6 | MiniSATA | Type F1 | 3.3V]
• SSDMAEMC080G2
• SSDMAEMC040G2
[?] https://www.intel.com/content/dam/www/public/ … ecification.pdf | https://www.millennium.ca/pdf/Intel_SSD_310_S … oduct_Brief.pdf
SSD 311 [SATA-2.6 | MiniSATA | Type F1 | 3.3V]
• SSDMAESC020G2
SSD 313 [SATA-2.6 | MiniSATA | Type F1 | 3.3V]
• SSDMAEXC024G3
• SSDMAEXC020G3
[!] SSDMAEXC024G3H is way more common than its standard non-OEM variant
SSD 525 [SATA-3.0 | MiniSATA | Type F1 | 3.3V]
• SSDMCEAC240B3
• SSDMCEAC180B3
• SSDMCEAC120B3
• SSDMCEAC090B3
• SSDMCEAC060B3
• SSDMCEAC030B3
[?] https://www.intel.com/content/dam/www/public/ … ecification.pdf | https://www.also.com/ec/cms5/media/img/5410_1 … d-525-brief.pdf
SSD 530 [SATA-3.0 | MiniSATA | Type F1 | 3.3V]
• SSDMCEAW240A4
• SSDMCEAW180A4
• SSDMCEAW120A4
• SSDMCEAW080A4
M.2 Next Generation form factor
SSD 530 [SATA-3.0 | M.2-2242 & 2280 | B+M key | 3.3V]
• SSDSCKHW360A4
• SSDSCKHW240A4
• SSDSCKGW180A4
• SSDSCKHW120A4
• SSDSCIHW120A4
• SSDSCKGW080A4
[!] 'KG' models are single-sided, 'KH' models are double-sided, 'IH' models are double-sided M.2-2242 drives
SSD 535 [SATA-3.2 | M.2-2280 | B+M key | 3.3V]
• SSDSCKJW360H6
• SSDSCKJW240H6
• SSDSCKJW180H6
• SSDSCKJW120H6
[!] 180GB models are single-sided but it's not reflected in the model code, the rest are double-sided
[?] https://www.intel.co.id/content/dam/www/publi … 535-m2-spec.pdf | https://www.mouser.com/datasheet/2/612/ssd-53 … rief-769408.pdf
SSD 540s [SATA-3.2 | M.2-2280 | B+M key | 3.3V]
• SSDSCKKW010X6
• SSDSCKKW480H6
• SSDSCKKW360H6
• SSDSCKKW240H6
• SSDSCKKW180H6
• SSDSCKKW120H6
[!] 1TB models are double-sided but it's not reflected in the model code, the rest are single-sided
[?] https://gzhls.at/blob/ldb/6/0/e/2/0a9947d8177 … 45ea65d0eaa.pdf | https://www.intel.com/content/dam/www/public/ … eries-brief.pdf
SSD 545s [SATA-3.2 | M.2-2280 | B+M key | 3.3V]
• SSDSCKKW512G8
• SSDSCKKW256G8
• SSDSCKKW128G8
SSD 600p (NVME 1.1) [PCIE 3.0 x4 | M.2-2280 | M key | 3.3V]
• SSDPEKKW010T7
• SSDPEKKW512G7
• SSDPEKKW256G7
• SSDPEKKW128G7
[?] no datasheet available | https://www.thailand.intel.com/content/dam/ww … -600p-brief.pdf
SSD 660p (NVME 1.3) [PCIE 3.0 x4 | M.2-2280 | M key | 3.3V]
• SSDPEKNW020T8
• SSDPEKNW010T8
• SSDPEKNW512G8
[?] no datasheet available | https://www.intel.com/content/dam/www/public/ … eries-brief.pdf
SSD 665p (NVME 1.3) [PCIE 3.0 x4 | M.2-2280 | M key | 3.3V]
• SSDPEKNW020T9
• SSDPEKNW010T9
[?] https://www.rutronik.com/fileadmin/user_uploa … 41351-002us.pdf | https://gzhls.at/blob/ldb/2/2/b/1/f0ba06aa787 … 5514be3159f.pdf
SSD 670p (NVME 1.4) [PCIE 3.0 x4 | M.2-2280 | M key | 3.3V]
• SSDPEKNU020TZ
• SSDPEKNU010TZ
• SSDPEKNU512GZ
[?] no datasheet available | https://www.mouser.com/datasheet/2/1383/ssd_6 … ief-2889107.pdf
SSD 760p (NVME 1.3) [PCIE 3.1 x4 | M.2-2280 | M key | 3.3V]
• SSDPEKKW020T8
• SSDPEKKW010T8
• SSDPEKKW512G8
• SSDPEKKW256G8
• SSDPEKKW128G8
[!] 2TB models are double-sided but it's not reflected in the model code
[?] no datasheet available | https://www.intel.com/content/dam/www/public/ … oduct-brief.pdf
Optane SSD 800P (NVME 1.1) [PCIE 3.0 x2 | M.2-2280 | B+M key | 3.3V]
• SSDPEK1W120GA
• SSDPEK1W060GA
[?] no datasheet available | https://www.mouser.com/pdfdocs/800p-series-product-brief.pdf
Optane SSD 905P (NVME 1.1) [PCIE 3.0 x4 | M.2-22110 | M key | 3.3V]
• SSDPEL1D380GA
[!] may be equipped with a heatspreader according to PCN117191-00
Optane SSD P1600X (NVME 1.3) [PCIE 3.0 x4 | M.2-2280 | M key | 3.3V]
• SSDPEK1A118GA
• SSDPEK1A058GA
[?] no datasheet available | https://d2pgu9s4sfmw1s.cloudfront.net/UAM/Pro … u~G3MBqC9soWA__
SSD Pro 1500 [SATA-3.0 | M.2-2242 & 2280 | B+M key | 3.3V]
• SSDSCKHF360A4
• SSDSCKHF240A4
• SSDSCKGF180A4
• SSDSCKHF120A4
• SSDSCIHF120A4
• SSDSCKGF080A4
SSD Pro 2500 [SATA-3.2 | M.2-2260 & 2280 | B+M key | 3.3V]
• SSDSCKJF360A5
• SSDSCKJF240A5
• SSDSCJJF240A5
• SSDSCKJF180A5
• SSDSCJJF180A5
[!] 'JJ' models are M.2-2260 drives, 'KJ' models are M.2-2280 drives. SSDSCKJF180A5 is single-sided, the rest are double-sided
[?] https://www.intel.la/content/dam/www/public/u … ecification.pdf | https://www.mouser.com/datasheet/2/612/ssd-pr … rief-780492.pdf
SSD Pro 5400s [SATA-3.2 | M.2-2280 | B+M key | 3.3V]
• SSDSCKKF010X6
• SSDSCKKF480H6
• SSDSCKKF360H6
• SSDSCKKF240H6
• SSDSCKKF180H6
• SSDSCKKF120H6
[?] https://www.netstoredirect.com/data-sheet?id_ … ttachment=27499 | http://8thgen.pillarglobalsolutionsinc.swcont … oduct_Brief.pdf
SSD Pro 5450s [SATA-3.2 | M.2-2280 | B+M key | 3.3V]
• SSDSCKKF512G8
• SSDSCKKF256G8
SSD Pro 6000p (NVME 1.1) [PCIE 3.0 x4 | M.2-2280 | M key | 3.3V]
• SSDPEKKF010T7
• SSDPEKKF512G7
• SSDPEKKF360G7
• SSDPEKKF256G7
• SSDPEKKF128G7
[?] no datasheet available | https://www.mouser.com/datasheet/2/146/ssd_pr … ief-2474541.pdf
SSD Pro 7600p (NVME 1.3) [PCIE 3.1 x4 | M.2-2280 | M key | 3.3V]
• SSDPEKKF020T8
• SSDPEKKF010T8
• SSDPEKKF512G8
• SSDPEKKF256G8
• SSDPEKKF128G8
SSD E 5100s [SATA-3.2 | M.2-2280 | B+M key | 3.3V]
• SSDSCKKR256G8
• SSDSCKKR128G8
• SSDSCKKR064G8
SSD E 5400s [SATA-3.2 | M.2-2280 | B+M key | 3.3V]
• SSDSCKKR180H6
• SSDSCKKR120H6
• SSDSCKKR080H6
• SSDSCKKR048H6
[?] https://www.intel.cn/content/dam/www/public/u … roduct-spec.pdf | no product brief available
SSD E 6000p (NVME 1.1) [PCIE 3.0 x4 | M.2-2280 | M key | 3.3V]
• SSDPEKKR256G7
• SSDPEKKR128G7
[?] no datasheet available | https://www.mouser.com/pdfdocs/e6000p-product-brief.pdf
SSD E 6100p (NVME 1.3) [PCIE 3.1 x4 | M.2-2280 | M key | 3.3V]
• SSDPEKKR256G8
• SSDPEKKR128G8
[?] no datasheet available | https://www.intel.la/content/dam/www/public/u … eries-brief.pdf
SSD E 7000s [SATA-3.2 | M.2-2280 | B+M key | 3.3V]
• SSDSCKJR960G7
• SSDSCKJR480G7
• SSDSCKJR240G7
• SSDSCKJR150G7
SSD DC S3110 [SATA-3.0 | M.2-2280 | B+M key | 3.3V]
• SSDSCKKI512G8
• SSDSCKKI256G8
• SSDSCKKI128G8
SSD DC S3500 [SATA-3.0 | M.2-2280 | B+M key | 3.3V]
• SSDSCKHB340G4
• SSDSCKHB120G4
• SSDSCKHB080G4
[!] all models are double-sided drives
SSD DC S3520 [SATA-3.0 | M.2-2280 | B+M key | 3.3V]
• SSDSCKJB960G7
• SSDSCKJB760G7
• SSDSCKJB480G7
• SSDSCKJB240G7
• SSDSCKJB150G7
SSD D3-S4510 [SATA-3.0 | M.2-2280 | B+M key | 3.3V]
• SSDSCKKB960G8
• SSDSCKKB480G8
• SSDSCKKB240G8
[!] a 1.92TB model is mentioned in the datasheet but it doesn't seem to exist
[?] https://www.solidigm.cn/wp-content/uploads/20 … 38122-001us.pdf | https://www.solidigm.com/content/dam/solidigm … oduct-brief.pdf
SSD DC P3100 (NVME 1.0) [PCIE 3.0 x4 | M.2-2280 | M key | 3.3V]
• SSDPEKKA010T7
• SSDPEKKA512G7
• SSDPEKKA256G7
• SSDPEKKA128G7
[?] no datasheet available | https://www.thailand.intel.com/content/dam/ww … p3100-brief.pdf
SSD DC P4101 (NVME 1.2) [PCIE 3.1 x4 | M.2-2280 | M key | 3.3V]
• SSDPEKKA020T8
• SSDPEKKA010T8
• SSDPEKKA512G8
• SSDPEKKA256G8
• SSDPEKKA128G8
[?] no datasheet available | https://m2m-enterprise.com/index.php/partners … intel/p-series/
SSD DC P4501 (NVME 1.2) [PCIE 3.1 x4 | M.2-22110 | M key | 3.3V]
• SSDPELKX040T7
• SSDPELKX020T7
• SSDPELKX010T7
• SSDPELKX500G7
[?] no datasheet available | https://www.chinaflashmarket.com/Uploads/file/Product report/SSD_report/intel/英特尔-p4501-brief.pdf
SSD DC P4510 (NVME 1.2b) [PCIE 3.1 x4 | M.2-22110 | M key | 3.3V]
• SSDPELKX020T8
• SSDPELKX010T8
[?] no datasheet available | https://m2m-enterprise.com/wp-content/uploads … eries-brief.pdf
Optane SSD DC P4801X (NVME 1.2d) [PCIE 3.0 x4 | M.2-22110 | M key | 3.3V]
• SSDPEL1K375GA
• SSDPEL1K200GA
• SSDPEL1K100GA
[?] no datasheet available | https://www.mouser.com/datasheet/2/612/optane … ief-1664144.pdf
SO-DIMM form factor
Turbo Memory 3.0 [PCIE 2.0 | Braidwood | 80-pin SO-DIMM | 3.3V]
• 2x 29F32G16NGNC ES
[?] never released
U.2 and PCI-Express card form factors
SSD 750 (NVME 1.0) [PCIE 3.0 x4 | U.2 SFF-8639 | 15mm tall | 12V]
• SSDPE2MW012T4
• SSDPE2MW800G4
• SSDPE2MW400G4
[?] https://www.intel.com/content/dam/www/public/ … sd-750-spec.pdf | https://ca.insight.com/content/dam/insight-we … d-750-brief.pdf
Optane SSD 900P (NVME 1.1) [PCIE 3.0 x4 | U.2 SFF-8639 | 15mm tall | 3.3+12V]
• SSDPE21D015TA
• SSDPE21D960GA
• SSDPE21D480GA
• SSDPE21D280GA
[!] all models excluding the 280GB model are branded as an Optane SSD 905P
[?] no datasheet available | https://www.intel.com/content/dam/www/public/ … -900p-brief.pdf
SSD DC P3500 (NVME 1.0) [PCIE 3.0 x4 | U.2 SFF-8639 | 15mm tall | 3.3+12V]
• SSDPE2MX020T4
• SSDPE2MX012T4
• SSDPE2MX400G4
[?] https://www.intel.com/content/dam/www/public/ … roduct-spec.pdf | https://www.intel.com/content/dam/www/public/ … -pcie-brief.pdf
SSD DC P3520 (NVME 1.1) [PCIE 3.0 x4 | U.2 SFF-8639 | 15mm tall | 3.3+12V]
• SSDPE2MX020T7
• SSDPE2MX012T7
• SSDPE2MX450G7
[?] no datasheet available | https://gzhls.at/blob/ldb/6/2/5/e/778a987aab5 … 0fd97dc566e.pdf
SSD DC P3600 (NVME 1.0) [PCIE 3.0 x4 | U.2 SFF-8639 | 15mm tall | 3.3+12V]
• SSDPE2ME020T4
• SSDPE2ME016T4
• SSDPE2ME012T4
• SSDPE2ME800G4
• SSDPE2ME400G4
[?] https://gzhls.at/blob/ldb/f/4/c/5/1f5df22211a … a2faad5b767.pdf | https://www.intel.com/content/dam/www/public/ … -pcie-brief.pdf
SSD DC P3700 (NVME 1.0) [PCIE 3.0 x4 | U.2 SFF-8639 | 15mm tall | 3.3+12V]
• SSDPE2MD020T4
• SSDPE2MD016T4
• SSDPE2MD800G4
• SSDPE2MD400G4
[?] https://tiscom.ru/sites/default/files/additio … -p3700-spec.pdf | https://www.intel.com/content/dam/www/public/ … -pcie-brief.pdf
SSD D5-P4320 (NVME 1.2) [PCIE 3.1 x4 | U.2 SFF-8639 | 15mm tall | 3.3+12V]
• SSDPE2NV076T8
[?] no datasheet available | https://www.solidigm.com/content/dam/solidigm … oduct-brief.pdf
SSD D5-P4420 (NVME 1.2) [PCIE 3.1 x4 | U.2 SFF-8639 | 15mm tall | 3.3+12V]
• SSDPE2NU076T8
SSD DC P4500 (NVME 1.2) [PCIE 3.1 x4 | U.2 SFF-8639 | 15mm tall | 3.3+12V]
• SSDPE2KX080T7
• SSDPE2KX040T7
• SSDPE2KX020T7
• SSDPE2KX010T7
[?] https://lenovopress.lenovo.com/lp0817.pdf | https://www.intel.com/content/dam/www/public/ … p4500-brief.pdf
SSD DC P4501 (NVME 1.2) [PCIE 3.1 x4 | U.2 SFF-8639 | 7mm tall | 3.3+12V]
• SSDPE7KX040T7
• SSDPE7KX020T7
• SSDPE7KX010T7
• SSDPE7KX500G7
SSD DC P4510 (NVME 1.2b) [PCIE 3.1 x4 | U.2 SFF-8639 | 15mm tall | 3.3+12V]
• SSDPE2KX080T8
• SSDPE2KX040T8
• SSDPE2KX020T8
• SSDPE2KX010T8
[?] https://lenovopress.lenovo.com/lp1033.pdf | https://www.solidigm.com/content/dam/solidigm … oduct-brief.pdf
SSD DC P4600 (NVME 1.2) [PCIE 3.1 x4 | U.2 SFF-8639 | 15mm tall | 3.3+12V]
• SSDPE2KE064T7
• SSDPE2KE032T7
• SSDPE2KE020T7
• SSDPE2KE016T7
[?] https://lenovopress.lenovo.com/lp0818-intel-p … -nvme-pcie-ssds | https://www.intel.com/content/dam/www/public/ … p4600-brief.pdf
SSD DC P4610 (NVME 1.2) [PCIE 3.1 x4 | U.2 SFF-8639 | 15mm tall | 3.3+12V]
• SSDPE2KE076T8
• SSDPE2KE064T8
• SSDPE2KE032T8
• SSDPE2KE016T8
[?] https://lenovopress.lenovo.com/lp1032.pdf | https://www.solidigm.com/content/dam/solidigm … oduct-brief.pdf
Optane SSD DC P4800X (NVME 1.2d) [PCIE 3.0 x4 | U.2 SFF-8639 | 15mm tall | 3.3+12V]
• (SSD/MDT)PE21K015TA
• (SSD/MDT)PE21(K/M)750GA
• (SSD/MDT)PE21(K/M)375GA
• SSDPE21K100GA
[!] 100GB models are branded as a P4801X. 'MDT' models have Memory Drive Technology, 'SSD' models don't have it. 'K' and 'M' differences are not known
[?] https://lenovopress.lenovo.com/lp0770-intel-o … e-nvme-pcie-ssd | https://www.mouser.com/datasheet/2/612/optane … ief-1664144.pdf
SSD D7-P5500 (NVME 1.3c) [PCIE 4.0 x4 | U.2 SFF-8639 | 15mm tall | 3.3+12V]
• SSDPF2KX076T9
• SSDPF2KX038T9
• SSDPF2KX019T9
[?] https://lenovopress.lenovo.com/lp1353-thinksy … nvme-pcie4-ssds | https://www.solidigm.com/content/dam/solidigm … eries-brief.pdf
SSD D7-P5600 (NVME 1.3c) [PCIE 4.0 x4 | U.2 SFF-8639 | 15mm tall | 3.3+12V]
• SSDPF2KE064T9
• SSDPF2KE032T9
• SSDPF2KE016T9
[?] https://lenovopress.lenovo.com/lp1354-thinksy … nvme-pcie4-ssds | https://www.solidigm.com/content/dam/solidigm … eries-brief.pdf
Optane SSD DC P5800X (NVME 1.3d) [PCIE 4.0 x4 | U.2 SFF-8639 | 15mm tall | 3.3+12V]
• SSDPF21Q032TB
• SSDPF21Q016TB
• SSDP(F/G)21Q800GB
• SSDP(F/G)21Q400GB
[!] 'F' models are single port, 'G' models are dual port
[?] https://lenovopress.lenovo.com/lp1484.pdf | https://www.intel.com/content/www/us/en/conte … brief-2023.html
Optane SSD DC P5810X (NVME 1.4) [PCIE 4.0 x4 | U.2 SFF-8639 | 15mm tall | 3.3+12V]
• SSDPF21Q800GA
• SSDPF21Q400GA
[?] no datasheet available | product brief not available
Optane SSD DC P5820X (NVME 1.4) [PCIE 4.0 x4 | U.2 SFF-8639 | 15mm tall | 3.3+12V]
• SSDPF21M016TA
• SSDPF21M800GA
• SSDPF21M400GA
SSD DC D3600 (NVME 1.2) [PCIE 3.0 x2 | U.2 SFF-8639 | 15mm tall | 3.3+12V]
• SSDPD2ME020T4
• SSDPD2ME010T4
[?] no datasheet available | https://www.content.shi.com/SHIcom/ContentAtt … d3600-brief.pdf
SSD DC D3700 (NVME 1.2) [PCIE 3.0 x2 | U.2 SFF-8639 | 15mm tall | 3.3+12V]
• SSDPD2MD016T4
• SSDPD2MD800G4
Optane SSD DC D4800X (NVME 1.2b) [PCIE 3.0 x2 | U.2 SFF-8639 | 15mm tall | 3.3+12V]
• SSDPD21K015TA
• SSDPD21K750GA
• SSDPD21K375GA
Standard PCI Express card form factor
SSD 750 (NVME 1.0) [PCIE 3.0 x4 | Single-slot, half-height, half-length | x4 connector | 3.3+12V]
• SSDPEDMW012T4
• SSDPEDMW800G4
• SSDPEDMW400G4
Optane SSD 900P (NVME 1.1) [PCIE 3.0 x4 | Single-slot, half-height, half-length | x4 connector | 3.3+12V]
• SSDPED1D015TA
• SSDPED1D960GA
• SSDPED1D480GA
• SSDPED1D280GA
[!] 960GB and 1.5TB models are branded as an Optane SSD 905P
SSD 910 [PCIE 2.0 x8 | Single-slot, half-height, half-length | x8 connector | 3.3+12V]
• SSDPEDOX800G3
• SSDPEDOX400G3
[?] https://www.intel.sg/content/dam/www/public/u … ecification.pdf | https://www.intel.de/content/dam/www/public/u … d-910-brief.pdf
SSD DC P3500 (NVME 1.0) [PCIE 3.0 x4 | Single-slot, half-height, half-length | x4 connector | 3.3+12V]
• SSDPEDMX020T4
• SSDPEDMX012T4
• SSDPEDMX400G4
SSD DC P3520 (NVME 1.1) [PCIE 3.0 x4 | Single-slot, half-height, half-length | x4 connector | 3.3+12V]
• SSDPEDMX020T7
• SSDPEDMX012T7
SSD DC P3600 (NVME 1.0) [PCIE 3.0 x4 | Single-slot, half-height, half-length | x4 connector | 3.3+12V]
• SSDPEDME020T4
• SSDPEDME016T4
• SSDPEDME012T4
• SSDPEDME800G4
• SSDPEDME400G4
SSD DC P3608 (NVME 1.0) [PCIE 3.0 x8 | Single-slot, half-height, half-length | x8 connector | 3.3+12V]
• SSDPECME040T4
• SSDPECME032T4
• SSDPECME016T4
[?] https://www.intel.com/content/dam/www/public/ … -p3608-spec.pdf | https://www.cpguard.com/datasheets/ssd-dc-p3608-brief.pdf
SSD DC P3700 (NVME 1.0) [PCIE 3.0 x4 | Single-slot, half-height, half-length | x4 connector | 3.3+12V]
• SSDPEDMD020T4
• SSDPEDMD016T4
• SSDPEDMD800G4
• SSDPEDMD400G4
SSD DC P4500 (NVME 1.2) [PCIE 3.1 x4 | Single-slot, half-height, half-length | x4 connector | 3.3+12V]
• SSDPEDKX080T7
• SSDPEDKX040T7
[?] https://lenovopress.lenovo.com/lp0850.pdf | https://www.intel.com/content/dam/www/public/ … p4500-brief.pdf
SSD DC P4600 (NVME 1.2) [PCIE 3.1 x4 | Single-slot, half-height, half-length | x4 connector | 3.3+12V]
• SSDPEDKE040T7
• SSDPEDKE020T7
[?] https://lenovopress.lenovo.com/lp0869-intel-p … -flash-adapters | https://www.intel.com/content/dam/www/public/ … p4600-brief.pdf
SSD DC P4608 (NVME 1.2b) [PCIE 3.1 x8 | Single-slot, half-height, half-length | x8 connector | 3.3+12V]
• SSDPECKE064T7
[!] may be found rebranded as the Oracle Flash Accelerator F640 PCIe Card
Optane SSD DC P4800X (NVME 1.2b) [PCIE 3.0 x4 | Single-slot, half-height, half-length | x3 connector | 3.3+12V]
• (SSD/MDT)PED1K015TA
• (SSD/MDT)PED1K750GA
• (SSD/MDT)PED1K375GA
[!] 'MDT' models have Memory Drive Technology, 'SSD' models don't have it
[?] no datasheet available | https://www.simms.co.uk/PDFS/Products/SSD/opt … 4801x-brief.pdf
Enterprise and Datacenter Standard form factor
Optane SSD DC P5801X (NVME 1.3d) [PCIE 4.0 x4 | E1.S SFF-TA-1006 | 25mm & 15mm tall | 12V]
• SSDPF(R/V)1Q800GB
• SSDPF(R/V)1Q400GB
[!] 'R' models are 25mm tall, 'V' models are 15mm tall
[?] no datasheet available | https://www.intel.com/content/www/us/en/produ … ifications.html
Optane SSD DC P5811X (NVME 1.4) [PCIE 4.0 x4 | E1.S SFF-TA-1006 | 25mm & 15mm tall | 12V]
• SSDPF(R/V)1Q800GA
• SSDPF(R/V)1Q400GA
SanDisk
1.8-inch form factor[/b]
SSD UATA 5000 1.8" [ATA-6 | ZIF | 8mm tall | 3.3V]
• SDU5B-064G-******
• SDU5B-032G-****** & SSD5K-****-S032
• SDU5B-016G-******
• SDU5B-008G-******
• SDU5B-004G-******
[?] https://tp.prosoft.ru/docs/shared/webdav_bizp … orce_download=1 | product brief not available
HP Mini 1000 SSD [ATA-6 | ZIF | 5mm tall | 3.3V]
• SDPA1AA-016G
• SDPA1AA-008G
[!] custom-built for HP without an 1.8" enclosure, height is a guess
C18-G3 [SATA-2.6 | MicroSATA | 8mm tall | 3.3V]
• SDS7AB-240G-***
• SDS7AB-120G-***
• SDS7AB-060G-***
[?] datasheet not available | https://media.dustin.eu/media/d20000100326722 … lc-document.pdf
SSD P4 [SATA-3.0 | MicroSATA | 4.4mm tall | 5V]
• SDSA4EH-128G-****
• SDSA4EH-064G-****
• SDSA4EH-032G-****
• SDSA4EH-016G-****
• SDSA4EH-008G-****
• SDSA4EH-004G-****
[?] https://datasheet.octopart.com/SDSA4AH-032G-S … et-10977758.pdf | product brief not available
SATA 5000 2.5" [SATA-1.0a | StandardSATA | 9.5mm tall | 5V]
• SDS5C-064G-******
• SDS5C-032G-******
• SDS5C-016G-******
• SDS5C-008G-******
[!] supports SATA-2.5 hotplugging, but not fully compliant with SATA-2.5
[?] https://media.digikey.com/pdf/Data Sheets/M-Systems Inc PDFs/SSD_SATA_5000_2.5_DS_Rev0.2.pdf | http://datasheet.elcodis.com/pdf/51/19/511940 … c064g0000e0.pdf
C25-G3 [SATA-2.6 | StandardSATA | 9.5mm tall | 5V]
• SDS7CB-240G-***
• SDS7CB-120G-***
• SDS7CB-060G-***
SSD P4 [SATA-3.0 | StandardSATA | 7mm tall | 5V]
• SDSA4(G/A/B)H-128G-****
• SDSA4(G/A/B)H-064G-****
• SDSA4(G/A/B)H-032G-****
• SDSA4(G/A/B)H-016G-****
• SDSA4(G/A/B)H-008G-****
• SDSA4(G/A/B)H-004G-****
[!] 'A' models are half-length drives with no housing, 'B' models are 'A' models with a larger screw mount diameter
SSD U100 [SATA-3.0 | StandardSATA | 7mm tall | 5V]
• SDSA5(G/A/B)K-256G-****
• SDSA5(G/A/B)K-128G-****
• SDSA5(G/A/B)K-064G-****
• SDSA5(G/A/B)K-032G-****
• SDSA5AK-024G-****
• SDSA5(G/A/B)K-016G-****
• SDSA5(G/A/B)K-008G-****
[!] some 'G' models may be labeled as an SSD P5. 'A' models are half-length drives with no housing, 'B' models are 'A' models with a larger screw mount diameter
[?] https://datasheet.ciiva.com/15223/getdatashee … 14-15223734.pdf | https://www.reactivedata.com/Products/ProductManuals/U100_SSD_Product Brochure.pdf
SSD U110 [SATA-3.0 | StandardSATA | 7mm tall | 5V]
• SDSA6GM-128G-****
• SDSA6GM-064G-****
• SDSA6(G/A)M-032G-****
• SDSA6(G/A)M-016G-****
• SDSA6AM-008G-****
[?] no datasheet available | https://xact.spiceworks.com/client_interactiv … _data_sheet.pdf
SSD X100 [SATA-3.0 | StandardSATA | 9.5mm & 7mm tall | 5V]
• SD5SB2-512G-****
• SD5S(B/C)2-256G-****
• SD5S(B/C)2-128G-****
• SD5S(B/C)2-064G-****
• SD5SB2-032G-****
[!] 'B' models are 7mm tall, 'C' models are 9.5mm tall
[?] https://datasheet.ciiva.com/15282/sd5sb2-128g-15282941.pdf | https://gzhls.at/blob/ldb/8/d/7/0/f79b236fd48 … 1af78561080.pdf
SSD X110 2.5" [SATA-3.1 | StandardSATA | 7mm tall | 5V]
• SD6S(B/A)1M-256G-****
• SD6S(B/A)1M-128G-****
• SD6S(B/A)1M-064G-****
• SD6S(B/A)1M-032G-****
[?] no datasheet available | https://www.mouser.com/datasheet/2/669/SanDis … 1713-805945.pdf
SSD X210 2.5" [SATA-3.1 | StandardSATA | 7mm tall | 5V]
• SD6SB2M-512G-****
• SD6SB2M-256G-****
• SD6SB2M-128G-****
[?] no datasheet available | https://www.mouser.com/datasheet/2/669/SanDis … 6_13-805929.pdf
SSD X300 SATA 2.5" [SATA-3.1 | StandardSATA | 7mm tall | 5V]
• SD7SB7S-010T-****
• SD7SB7S-512G-****
• SD7SB6S-256G-****
• SD7SB6S-128G-****
[!] some models are labeled as an X300 2.5" 7MM
[?] no datasheet available | https://downloads.sandisk.com/downloads/datas … 0-datasheet.pdf
SSD X300s SATA [SATA-3.2 | StandardSATA | 7mm tall | 5V]
• SD7UB2Q-010T-****
• SD7UB2Q-512G-****
• SD7UB3Q-256G-****
• SD7UB3Q-128G-****
• SD7SB3Q-064G-****
[?] no datasheet available | https://downloads.sandisk.com/downloads/datas … s-datasheet.pdf
X300DC SSD SATA 2.5" [SATA-3.2 | StandardSATA | 7mm tall | 5V]
• SD7SB7S-960G-****
• SD7SB7S-512G-****
[!] the 512GB model is a X300 specifically built for the ThinkPad E560p
[?] no datasheet available | https://www.solidstateworks.com/datasheets/X3 … tasheet-1_3.pdf
SSD X400 SATA 2.5" [SATA-3.2 | StandardSATA | 7mm tall | 5V]
• SD8(S/T)B8U-1T00-****
• SD8(S/T)B8U-512G-****
• SD8(S/T)B8U-256G-****
• SD8(S/T)B8U-128G-****
[!] 'T' models are OPAL self encrypting drives. some models are labeled as an X400 2.5" 7MM
[?] no datasheet available | https://www.sandisk.com/content/dam/sandisk-m … asheet-v1-1.pdf
SSD X600 SATA 2.5" [SATA-3.2 | StandardSATA | 7mm tall | 5V]
• SD9(S/T)B8W-2T00-****
• SD9(S/T)B8W-1T00-****
• SD9(S/T)B8W-512G-****
• SD9(S/T)B8W-256G-****
• SD9(S/T)B8W-128G-****
[!] 'T' models are OPAL self encrypting drives. some models are labeled as an X600 SSD SATA 2.5"
[?] no datasheet available | https://www.sandisk.com/content/dam/sandisk-m … -Data-Sheet.pdf
SSD Z400s SATA [SATA-3.0 | StandardSATA | 7mm tall | 5V]
• SD8SBAT-256G-****
• SD8SBAT-128G-****
• SD8SBAT-064G-****
• SD8SBAT-032G-****
[?] no datasheet available | https://www.sandisk.com/content/dam/sandisk-m … 0s-embedded.pdf
SSD Z410 SATA [SATA-3.0 | StandardSATA | 7mm tall | 5V]
• SD8SBBU-480G-****
• SD8SBBU-240G-****
• SD8SBBU-120G-****
[?] no datasheet available | https://www.prodimex.ch/sandisk-z410-ssd-sata-6-gb_s-2.5”-480-gb-sd8sbbu-480g-1122-99456_en.pdf
ReadyCache SSD [SATA-3.0 | StandardSATA | 7mm tall | 5V]
• SDSSDRC-032G-***
[?] no datasheet available | https://datasheet.ciiva.com/48428/sdssdrc-032 … et-48428838.pdf
• SDSSDP-256G-***
• SDSSDP-128G-***
• SDSSDP-064G-***
• SDSSDP-032G-****
• SDSSDP-016G-****
[!] originally named as the Pulse SSD, now it's just SSD
[?] no datasheet available | https://www.prodimex.ch/sandisk-ssd-sata-6-gb_s-2.5''-64-gb-sdssdp-064g-g25-75662_en.pdf
SSD PLUS [SATA-3.0 | StandardSATA | 7mm tall | 5V]
• SDSSDA-2T00-***
• SDSSDA-1T00-***
• SDSSDA-960G-***
• SDSSDA-500G-***
• SDSSDA-480G-***
• SDSSDA-250G-***
• SDSSDA-240G-***
• SDSSDA-120G-***
[?] no datasheet available | https://documents.westerndigital.com/content/ … ata-iii-ssd.pdf https://documents.sandisk.com/content/dam/ass … d-plus-sata.pdf
Extreme SSD [SATA-3.0 | StandardSATA | 9.9mm tall | 5V]
• SDSSDX-480G-***
• SDSSDX-240G-***
• SDSSDX-120G-***
• SDSSDX-060G-***
[?] no datasheet available | https://downloads.sandisk.com/downloads/qsg/e … d-datasheet.pdf
Extreme II SSD [SATA-3.0 | StandardSATA | 7mm tall | 5V]
• SDSSDXP-480G-***
• SDSSDXP-240G-***
• SDSSDXP-120G-***
[?] no datasheet available | https://mp3support.sandisk.com/downloads/qsg/ … d-datasheet.pdf
Extreme PRO SSD [SATA-3.0 | StandardSATA | 7mm tall | 5V]
• SDSSDXPS-960G-***
• SDSSDXPS-480G-***
• SDSSDXPS-240G-***
[?] no datasheet available | https://manuals.coolblue.nl/3a/sandisk-extrem … e-ssd-500gb.pdf
Ultra SSD [SATA-2.6 | StandardSATA | 9.9mm tall | 5V]
• SDSSDH-240G-***
• SDSSDH-120G-***
• SDSSDH-060G-***
Ultra II SSD [SATA-3.0 | StandardSATA | 7mm tall | 5V]
• SDSSDHII-960G-***
• SDSSDHII-480G-***
• SDSSDHII-240G-***
• SDSSDHII-120G-***
[?] no datasheet available | https://downloads.sandisk.com/downloads/qsg/u … d-datasheet.pdf
Ultra Plus SSD [SATA-3.0 | StandardSATA | 7mm tall | 5V]
• SDSSDHP-256G-***
• SDSSDHP-128G-***
• SDSSDHP-064G-***
Ultra 3D SSD [SATA-3.0 | StandardSATA | 7mm tall | 5V]
• SDSSDH3-4T00-***
• SDSSDH3-2T00-***
• SDSSDH3-1T00-***
• SDSSDH3-500G-***
• SDSSDH3-250G-***
CloudSpeed 1000 SSD [SATA-3.1 | StandardSATA | 7mm tall | 5V]
• SDLFGC7R-960G-****
• SDLFGD7R-480G-****
• SDLFGD7R-240G-****
• SDLFGE7R-120G-****
[?] http://yannajohansen.com/files/2018-06-13_11_ … duct_manual.pdf | https://www.also.com/ec/cms5/media/documents/ … 42014_final.pdf
CloudSpeed 1000E SSD [SATA-3.1 | StandardSATA | 7mm tall | 5V]
• SDLFGC7R-800G-****
• SDLFGD7R-400G-****
• SDLFGD7R-200G-****
• SDLFGE7R-100G-****
CloudSpeed Eco SSD [SATA-3.1 | StandardSATA | 7mm tall | 5V]
• SDLFNCAR-960G-****
• SDLFNDAR-480G-****
• SDLFNDAR-240G-****
[?] https://downloads.sandisk.com/downloads/ess/c … oduct-specs.pdf | https://downloads.sandisk.com/downloads/ess/c … d-datasheet.pdf
CloudSpeed Eco Gen. II SSD [SATA-3.2 | StandardSATA | 7.17mm tall | 5V]
• SDLF1CRR-019T-****
• SDLF1DAR-960G-****
• SDLF1DAR-480G-****
[?] https://downloads.sandisk.com/downloads/ess/c … oduct-specs.pdf | https://www.sandisk.com/content/dam/sandisk-m … d-datasheet.pdf
CloudSpeed Ascend SSD [SATA-3.1 | StandardSATA | 7mm tall | 5V]
• SDLFOCAR-960G-****
• SDLFODAR-480G-****
• SDLFODAR-240G-****
• SDLFOEAR-120G-****
[?] no datasheet available | https://downloads.sandisk.com/downloads/ess/c … d-datasheet.pdf
CloudSpeed Ultra SSD [SATA-3.1 | StandardSATA | 7mm tall | 5V]
• SDLFOCAM-800G-****
• SDLFODAM-400G-****
• SDLFODAM-200G-****
• SDLFOEAM-100G-****
CloudSpeed Ultra Gen. II SSD [SATA-3.2 | StandardSATA | 7.17mm tall | 5V]
• SDLF1CRM-016T-****
• SDLF1DAM-800G-****
• SDLF1DAM-400G-****
SSD P3 [SATA-3.0 | MiniSATA | Type F1 | 3.3V]
• SDSA3DD-064G
• SDSA3DD-032G
• SDSA3DD-016G
• SDSA3DD-008G
[!] product name is not confirmed
SSD P4 [SATA-3.0 | MiniSATA | Type F1 & H1 | 3.3V]
• SDSA4DH-128G-****
• SDSA4(D/F)H-064G-****
• SDSA4(D/F)H-032G-****
• SDSA4(D/F)H-016G-****
• SDSA4(D/F)H-008G-****
• SDSA4(D/F)H-004G-****
[!] 'F' models are Type H1 cards, 'D' models are Type F1 cards
SSD U100 [SATA-3.0 | MiniSATA | Type F1 & H1 | 3.3V]
• SDSA5DK-256G-****
• SDSA5(D/F)K-128G-****
• SDSA5(D/F)K-064G-****
• SDSA5DK-060G-****
• SDSA5(D/F)K-032G-****
• SDSA5(D/F)K-024G-****
• SDSA5(D/F)K-016G-****
• SDSA5(D/F)K-008G-****
SSD U110 [SATA-3.0 | MiniSATA | Type F1 & H1 | 3.3V]
• SDSA6(D/F)M-032G-****
• SDSA6(D/F)M-024G-****
• SDSA6(D/F)M-016G-****
SSD X100 [SATA-3.0 | MiniSATA | Type F1 | 3.3V]
• SD5SF2-256G-****
• SD5SF2-128G-****
• SD5SF2-064G-****
• SD5SF2-032G-****
SSD X110 [SATA-3.1 | MiniSATA | Type F1 | 3.3V]
• SD6SF1M-256G-****
• SD6SF1M-128G-****
• SD6SF1M-064G-****
• SD6SF1M-032G-****
[!] some models are labeled as an X110 MSATA
[?] no datasheet available | https://www.reactivedata.com/Downloads/sandisk/eol/PCN-000001747-C X110 and X210 EOL.pdf
X300 SSD MSATA [SATA-3.1 | MiniSATA | Type F1 | 3.3V]
• SD7SF6S-512G-****
• SD7SF6S-256G-****
• SD7SF6S-128G-****
[!] some models are labeled as an X300 MSATA
Z400s SSD mSATA [SATA-3.0 | MiniSATA | Type F1 | 3.3V]
• SD8SFAT-128G-****
• SD8SFAT-064G-****
• SD8SFAT-032G-****
Ultra II mSATA [SATA-3.0 | MiniSATA | Type F1 | 3.3V]
• SDMSATA-512G-***
• SDMSATA-256G-***
• SDMSATA-128G-***
SSD U110 [SATA-3.0 | M.2-2242 & 2260 | B+M key | 3.3V]
• SDSA6PM-128G-****
• SDSA6PM-064G-****
• SDSA6MM-032G-****
• SDSA6MM-024G-****
• SDSA6MM-016G-****
• SDSA6MM-008G-****
[!] 'M' models are 42mm long, 'P' models are 60mm long
SSD X110 [SATA-3.1 | M.2-2260 & 2280 | B+M key | 3.3V]
• SD6S(P/N)1M-256G-****
• SD6S(P/N)1M-128G-****
• SD6SP1M-064G-****
[!] 'P' models are 60mm long, 'N' models are 80mm long
SSD X300 M.2 2280 [SATA-3.1 | M.2-2280 | B+M key | 3.3V]
• SD7SN6S-512G-****
• SD7SN6S-256G-****
• SD7SN6S-128G-****
[!] some models are labeled as an X300 M.2 2280
SSD X300s M.2 2280 [SATA-3.2 | M.2-2280 | B+M key | 3.3V]
• SD7UN3Q-512G-****
• SD7UN3Q-256G-****
• SD7UN3Q-128G-****
• SD7SN3Q-064G-****
SSD X400 M.2 2280 [SATA-3.2 | M.2-2280 | B+M key | 3.3V]
• SD8SN8U-1T00-****
• SD8SN8U-512G-****
• SD8SN8U-256G-****
• SD8SN8U-128G-****
SSD X600 SATA M.2 2280 [SATA-3.2 | M.2-2280 | B+M key | 3.3V]
• SD9(S/T)N8W-2T00-****
• SD9(S/T)N8W-1T00-****
• SD9(S/T)N8W-512G-****
• SD9(S/T)N8W-256G-****
• SD9(S/T)N8W-128G-****
SSD Z400s M.2 2242/2280 [SATA-3.0 | M.2-2242 & 2280 | B+M key | 3.3V]
• SD8SNAT-256G-****
• SD8S(M/N)AT-128G-****
• SD8S(M/N)AT-064G-****
• SD8SMAT-032G-****
[!] 'M' models are 42mm long, 'N' models are 80mm long
SSD A110 M.2 2260 (AHCI 1.3) [PCIE 2.0 x2 | M.2-2260 | B+M key | 3.3V]
• SD6PP4M-256G-****
• SD6PP4M-128G-****
[!] some models are labeled as an SSD A110
[?] no datasheet available | no product brief available
SDNEP (NVME 1.0) [PCIE 2.0 x2 | M.2-2280 | E key | 3.3V]
• SD6PQ4M-512G-****
• SD6PQ4M-256G-****
• SD6PQ4M-128G-****
[!] custom-built for Apple, known as the GS3N on SanDisk's website
SSD PLUS M.2 NVMe (1.3) SSD [PCIE 3.0 x4 | M.2-2280 | M key | 3.3V]
• SDSSDA3N-2T00-***
• SDSSDA3N-1T00-***
• SDSSDA3N-500G-***
• SDSSDA3N-250G-***
[?] no datasheet available | https://documents.sandisk.com/content/dam/ass … lus-m2-nvme.pdf
Extreme M.2 NVMe (1.3) SSD [PCIE 3.0 x4 | M.2-2280 | M key | 3.3V]
• SDSSDX3N-2T00-***
• SDSSDX3N-1T00-***
• SDSSDX3N-500G-***
[?] no datasheet available | https://documents.westerndigital.com/content/ … eme-m2-nvme.pdf
Extreme PRO M.2 NVMe (1.3) 3D SSD [PCIE 3.0 x4 | M.2-2280 | M key | 3.3V]
• SDSSDXPM2-2T00-***
• SDSSDXPM2-1T00-***
• SDSSDXPM2-500G-***
[?] no datasheet available | https://documents.westerndigital.com/content/ … nvme-3d-ssd.pdf
