First post, by Miphee
- Oldbie
Images are not mine.
SAT-402A 2EC0BIPB49900
It appears to be a system on a card.
OEM, not retail.
Here's the rest of the system:
https://archiwum.allegro.pl/oferta/sanyo-pc-3 … 7674437634.html
The model is right there on the card. SAT 402A.
It's kind of neat in that it has a socketted 386sx, and some weird SIPP sockets.
I don't see a motherboard, does this work in any standard ISA slot or is it proprietary?
Well, you'll need an ISA backplane to get this SBC working.
has all kinds of stuff
I have similar, unopened in box, 286 sanyo machine waiting for me to do unboxing video of it.
A little about software engineering: https://byteaether.github.io/
Sadly information is scarce, including a motherboard picture. Sanyo apparently had a thing for compact systems.
As for what it would do if you connected it to a slot that already had a system, my guess is nothing, what would it do? It may be ISA but the application is unquestionably proprietary. Sanyo also at some point made less than fully compatible clones. I have no idea if this system (it's an MBC-18SXMT1 as you can see) falls into that category.
Seems like one of their last products.
Okay guys, thank you very much!
FYI - have the same card, figured out the keyboard connector pinout and got it running.
I've bought it from a guy from england, using it for checking desoldered 386/486slc-chips.
EDIT: found a similar board (only ram layout seems to differ):
https://stason.org/TULARC/pc/motherboards/S/S … X-MBC-18SX.html
