First post, by chublord
I know it will not install on a 486 (installer will check), but would it *run* on a 486 DX4-100, if it were installed using a different chip (like the Pentium Overdrive)? Or installed using a different computer?
I'm sure it will be slow but I'm curious if its possible.
IBM Valuepoint 486 DX4-100, Opti 802G, 50 MHz FSB, Voodoo1+S3 864, Quantum Fireball EX 4.0 GB, Seagate Medalist 1.6 GB, 128 MB FPM, 256k L2
Reply 1 of 18, by Jo22
Yes, it will. 😀
The people at winhistory.de did some experiments with XP on old hardware.
https://www.winhistory.de/more/386/xpmini.htm
English Translation
Reply 2 of 18, by Standard Def Steve
Jo22 wrote on 2020-08-06, 20:53:
Yes, it will. :) […]
Yes, it will. 😀
English Translation
But that's not really a 486. It's a Pentium bolted to a 486 socket.
XP's kernel has Pentium instructions, so even though it will boot on a POD underclocked to 8MHz, it won't run on a true 486. Not even a 100MHz DX4.
"A little sign-in here, a touch of WiFi there..."
Reply 3 of 18, by Jo22
Hi, I think it depends on point of view.
On the other hand, a lot of people don't consider a 386 mainboard with a 486DLX/SLC CPU or Rapidcad CPU as a true 486, either.
On the other hand (again), some people don't consider an am586 or 486dx4 as real 486 CPUs, either.
The latter seems strange, but the 486dx4 was said to have incompatibility issues with some 486-optimized games.
Perhaps because it was not based on the original 486 design anymore, which the 486DX2 also was based on.
Reply 4 of 18, by chublord
Sorry, I probably wasn't clear on my intent.
If I installed WinXP on a Pentium Overdrive Socket 3 system, then replaced that Pentium overdrive with a 486 DX4-100, would XP run?
Reply 5 of 18, by jakethompson1
Looks like ntoskrnl.exe has some cmpxchg8b instructions in it. Unless it's carefully coded to avoid doing those on a 486, it would crash as soon as it hit one.
Reply 6 of 18, by leileilol
Yeah XP would never run on a 486 even if you swap CPUs after. It's not a requirement "on paper" like most things, it really needs those instructions. I've seen some 486 XP bullshitters before...
Win2000 will run on a 486 though! Probably not after a certain service pack however...
Reply 7 of 18, by jakethompson1
Kind of the same issue people are facing with all sorts of stuff requiring SSE2 now vs. their Pentium III and Athlon XP machines.
Reply 8 of 18, by Jo22
leileilol wrote on 2020-08-07, 00:18:
Win2000 is kinda special also, because it was the last OS to run on PC-98 platform.
It also was the last OS with useable HPFS support and an intact POSIX and OS/2 subsystem.
W2K could even run Presentation Manager programs for OS/2 1.x once that mysterious "Microsoft OS2 Presentation Manager For NT" was installed.
In this respect it was really a professional OS, IMHO. If it had its GUI running in user-mode, like NT 3.x had, it would have been perfect.
Reply 9 of 18, by jakethompson1
It's also possible the kernel will check the processor on every boot rather than just at install time. It isn't like Win95/98 where processors without cpuid were supported.
Reply 10 of 18, by chublord
Thanks for the replies! Guess Windows 2000 is the latest and greatest for this machine.
I do have Win2000 SP4 running on it already. Nice little OS and surprisingly usable even on a 486.
Reply 11 of 18, by chinny22
Was going to say latest but not so sure on greatest?
But as you seem happy enough with its speed I guess it's true.
is this the IBM in your sig? Ran NT4 on a DX2/66 with 64MB Ram towards end of it's life back in the day. Took an age to start but once booted it mad for a good basic office/internet PC for homework, etc and lot more stable then 95
it also left the faster PC free for gaming 😀
Reply 12 of 18, by HandOfFate
jakethompson1 wrote on 2020-08-07, 00:26:
Even the socket 939 Athlon 64s are hitting a wall at Windows 8.1. They don't support the "CMPXCHG16b" instruction and either crash/reboot when starting the install (my experience) or report "You can't install Windows 8.1 because your processor doesn't support CompareExchange128." (according to The Internet)
chublord wrote on 2020-08-07, 01:49:
That's cool. I will have to try that. If everything works I would be able to get my USB wifi adapter (that surprisingly enough had Win2k drivers and utilities) working on a 486, that would be very useful.
Did you have to do anything special to get it running?
Am486 DX4 120MHz, no L2, 16MB, Tseng ET4000/W32 1MB VLB, ESS ES1869 /// 5x86 133MHz, 256kb L2, 64MB, S3 Virge/DX 4MB PCI, SB16 + Yucatan FX, PicoGUS /// Pentium III 1GHz, 512MB, Asus V7700 64MB AGP, SB Live!
Reply 13 of 18, by Anonymous Coward
The real question is why would you want XP running on a 486? NT4 and 2k were already taxing enough as it was. Even on my PIII-700 Windows XP felt like a dog compared to 2k.
Reply 14 of 18, by chinny22
I'd say its the challenge to get the newest possible copy of windows running. Not to actually use it.
like how some like the challenge of upgrading windows 1 or whatever to 10, Can't image anything worse to actually use but can understand the appeal of the challenge alone then simply format the thing
Reply 15 of 18, by Jo22
Anonymous Coward wrote on 2020-08-07, 12:31:
Must depend on the amount of RAM and version of XP, then.
I remember that Windows XP was the "best" OS for my Pentium MMX 166MHz with 64MB RAM and a 2GB SCSI HDD.
It was XP that made it possible that SNES9x ran playable first time. It could run TinyToons more or less smoothly (with frameskip).
Other emulators that used to crash on 98SE
previously, ran fine on XP at first time.
Personally, XP was a relief for me. Even on totally underpowered hardware.
Reply 16 of 18, by Anonymous Coward
I'm not sure what it was about XP that made SNES9x run faster, but pretty much everything I ran on it was slower (and less stable). Better directx support?
Reply 17 of 18, by chublord
I'm still trying to get this connected to my distributed computing client (BOINC). It's not going to add any meaningful computing power to it, but would be cool if it worked. The client is not compatible with Win2000.
chinny22 wrote on 2020-08-07, 10:57:
Was going to say latest but not so sure on greatest? But as you seem happy enough with its speed I guess it's true. […]
Yeah that's the machine in my sig. More RAM would definitely help for Win2000 but it's ok to use. Increasing the FSB speed from 33 to 50 MHz made a huge difference in "feel".
Reply 18 of 18, by Jo22
Quick update. Meanwhile since this thread was opened years ago, a programmer had successfully patched Windows XP to run on i486.
It's being mentioned over here: Someone got xp sp3 running on a 486
Anyway, just thought I should mention it here, so forum visitors are made aware of current situation.
