First post, by Rodney Dawn
I'm looking to build a new dualboot system for win9x gaming, and a small install of win7 basic 32bit (just for websurfing as ME has difficulties due to sites using new TLS and firefox 2 not supporting those https sites.
The primary use of this machine will be to run windows ME (the 9x i like best and have a great many years experience using) to play old DX games, and some newer dos titles (which run fine from dos within windows on ME)
The difficulty is needing win7 for basic browsing (googling, gamefaqs type stuff) and having the absolute bare minimum to run 7 without breaking compatibility for ME or any 9x games.
I have determined that a p4 northwood 2.0\512k\400 cpu and a chipset supporting DDR (845 or 865) will suit my needs, and I know all the power tweaks to run ME on greater than 512 ram (up to 1gb max), the difficulty is in determining which 845 or 865 motherboards actually have drivers for ME (presumably all work with 7 but missing drivers on 7 would hardly matter so long as it installs and has funtioning LAN port. AGP is a must, as I will be using a 128mb fx5500 graphics card. (''just barely'' works with 7 but runs great on ME)
I'm hoping to find a motherboard with a native ATA133 controller, and a floppy controller (will have both a 3.5 and 5.25) but am planning to use an addon pci IDE (non raid) controller if anyone can recommend one that fully supports ME.
OS drives will be 64gb DOM SSD's for ME and 7, (one on addin card and one on primary IDE of motherboard, or both on addin card with a shared 120gb mechanical HDD (FAT32) slaved to the DVD-r-DL drive on the motherboard secondary IDE channel.
I dont have to have working sound in 7, but sound has to work in ME.
ISA is not a ''must'', but having a proper DMA isa slot would make adding legacy peripherals simpler, as I have several old ISA serial port cards which I know work with ME.
Onboard LAN must work on ME also, as I will be using the PC on a LAN for old 9x LAN games. (wifi is irrelavant as I have a wifi to ethernet minibridge to connect the LAN port to.)
I'm not really partial to any brand of motherboard in particular, but would prefer a solid quality board form a major supplier like ASUS, Gigabyte, MSI, etc. Stability and 9x compatibility are most important factors, as well as support for a northwood 2.0/512/400 cpu. (I know athlonxp is faster but I have the northwood chip already and nothing else to do with it).
not sure if this is the correct subforum to ask for help picking a motherboard for such a build, but I've enjoyed reading about all the interesting old hardware and figured people here might know what motherboard is best for this build.
For the curious, I also have a 486dx100 with both vlb and pci running ME, (previous owner had 95 on it but I always found 95 crash prone so I upgraded it to ME) with a Mach32VLb and voodoo1 PCI that I use for word processing, and spreadsheet work. (I know the voodoo card is kinda overkill for that, but it does seem to make the machine a little more responsive for some reason. (have to use the setup /nm switch to get ME to install on a 486 in case anyone is curious) HDD is a quantum bigfoot 2gb as the controller didn't play well with the 3.2gb wd caviar SE I had on it to begin with. no issues at all with the bigfoot though.
(I have also got win ME to boot (very slowly) on a 386, by using another computer to do the install (you just can squeeze a bare minimum install on a 500mb drive with almost no room to spare) and then returning the drive to the 386. just to see if it would work. I have the 387 coprocessor installed on that machine though, and 8mb ram, so cant say if it would boot without it.
Reply 1 of 16, by kolderman
Getting working ISA on P4 will be difficult to find.
Reply 2 of 16, by Rodney Dawn
as long as the board has at least 1 functional serial port, and the sound works on windows ME then I can manage without ISA.
Reply 3 of 16, by kolderman
Rodney Dawn wrote on 2020-08-09, 01:31:
Sound will work, but getting it working on dos games might be a bit hit and miss. Depending on the card and game. What sound card will you use?
Reply 4 of 16, by cyclone3d
What is your budget?
A good P4 setup with ISA with working DMA is going to generally run you $300+
Here is an ATX board on eBay that will fit your requirements - not my sale:
https://www.ebay.com/itm/1pc-used-Advantech-I … t2/143440598444
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 5 of 16, by Horun
Good ! Because socket 478 with ISA are not rare but those with true ISA and 845, 848 or 865 based are not cheap . (Not saying they are not around but in general NO unless you have very deep pockets hahhaaa). I really like my MSI 865PE-NEO2 and Giga 8iPE1000 soc 478. But no ISA on either but they have at least one Com port and a Parallel port too.
cyclone3d wrote on 2020-08-09, 02:13:
Yes those with real ISA are not cheap 😀
Reply 6 of 16, by kalohimal
You could perform an eBay search with keywords "845" and "isa". If you could live with 1 ISA slot, there are cheap ones around like these:
https://www.ebay.com/itm/Gigabyte-Intel-D845G … wsAAOSwtl5dCQjO
https://www.ebay.com/itm/MS-6555-OEM-Intel-D8 … xMAAOSwJq1ZZZUt
USD60 comes complete with CPU and RAM.
Slow down your CPU with CPUSPD for DOS retro gaming.
Reply 7 of 16, by Horun
kalohimal wrote on 2020-08-09, 02:28:
You could perform an eBay search with keywords "845" and "isa". If you could live with 1 ISA slot, there are cheap ones around […]
They are cheap (in comparison to others) because no AGP slot.
Reply 8 of 16, by kalohimal
Obviously 😊
Reply 9 of 16, by Rodney Dawn
Thanks 😀
Unfortunately the boards without AGP would not fit my needs.
I have a few different PCI Soundblaster cards which I know have ME drivers, though if I can get a board with 1 proper DMA ISA slot I have a selection of nice ''true'' Soundblaster 16 cards to choose from.
as for budget, anywhere in the 300-500.00 range would be ideal. I'd rather pay more for a solid reliable board, than save a few $$$ and end up with a flaky system because of shoddy motherboard. I'm going all out with this build, including a relatively modern gamer case,(old enough to have two external 5.25 bays for dvd and floppy and one external 3.5 for the other floppy, but new enough it looks flashy and supports watercooling. I'm also going to use an AIO watercooler ( waterblock bracket modded to fit S478) to make for a very quiet system. sort of a 'sleeper' build as it will look all modern when powered off, but is actually a 9x gaming rig beneath the flashy modern exterior. (Unless you look close enough to see the "Designed for Windows ME" case decal (pulled from a dead laptop and carefully attached to new case with a tiny drop of epoxy spread evenly to prevent peeling. I also bought an unopened "retail full" copy of windows ME off ebay, specifically for this build. (I still have my original from back in the day, kept in a cd protector case, but for this build it just felt right buying another copy. I'll post some pics when I get it done, and run some 9x benches if anyone is interested. Using specialty overclockers' DDR500 simply because I can run it at DDR400/333/266 with much tighter timings and due to the DIMMs using high quality chips.
Reply 10 of 16, by kalohimal
With that budget you can consider a 478 industrial board with ISA. I have one and the ISA slot does have proper DMA and my sound blaster AWE 32 works well on it. I use it basically as a 3-in-1 system that runs DOS, Win98SE and XP. Mine is the single ISA slot version which is cheaper. With your budget you can go for the 3 slots version. Bear in mind though, just like other China brand boards, the support is non existence.
The attachment HT845GV1.jpg is no longer available
Reply 11 of 16, by cyclone3d
So order the board I posted a link to. It is made by Advantech. Probably never have to worry about it dying. And it should accept the Gallatin extreme edition CPUs as well. Prescott should work as well but IMO the Gallatin is better and should run cooler.
That being said, another option would be to get a PCIAGP/PXAGP backplane with the P-ISA bridge card and an SAGP 865 based SBC. That will end up being more around the $400-$500 mark but you will have a lot more slots to play with.
YMF7x4 Guide
Reply 12 of 16, by OSkar000
Do you really need to be able to run Win7 on it?
From my experience it needs at least 1gb ram to be somewhat useful. With just 512mb you should be happy if you can even start a a web browser. Minimum to be usable is around 4gb but thats mostly not enough.
Reply 13 of 16, by red-ray
Rodney Dawn wrote on 2020-08-08, 22:28:
I have Windows Me running on a system with 2GB of RAM and suggest that given you wish to run 32-bit Windows 7 feel you should install 2GB.
Reply 14 of 16, by Rodney Dawn
cyclone3d wrote on 2020-08-09, 17:21:
Thanks 😀 that looks to be exactly what I am looking for.
Reply 15 of 16, by Rodney Dawn
red-ray wrote on 2020-08-09, 18:54:
As I said I'll have 1gb to start with. I can always add another gb later on as I have several tested 1gb and 512mb sticks of DDR500 (for tight timings at conventional speeds).
Reply 16 of 16, by Rodney Dawn
I may have to go up to 2gb, but 1gb should be sufficient as its just for web browsing. I have an FX8350 running 7 for normal modern computing needs, as well as an Opteron 3280 which dual boots 7 and whatever linux distro I happen to be playing with at the time (currently Kali Linux KDE). so I really only need 7 to run bare minimum on the P4, just so I dont have to switch machines to go look something up on gamefaqs. Of course I used to work around that issue by using KernelEX and Opera, on ME, but with more sites switching to an even stricter TLS BS, its hit or mis if that will work anymore. (probably wont be long before someone has to make something similar to KernelEx for 7 the way things are going, and 7 is the last windows I will ever use. I tried the bloated spywere laden 8 8.1 and 10 for a brief period each on the Opteron, and always ended up ''upgrading'' back to 7. Of course as much as I like 7, I would still be running ME exclusively if not for lack of drivers for newer hardware, and the stupid TLS issues getting harder to deal with. I use classic view, and custom icons to make 7 feel more like ME, but its not the same. even on the Opteron with a fast PCIE SSD there is a noticeable delay in actions, which anything 2ghz or better and a fast ATA133 drive will do nearly instantaneously on ME. I like 7, but I still enjoy ME a lot more.
