First post, by pan069
I have heard stories regarding tantalum capacitors exploding with the possibility of nasty side effects (other than taking an eye out). So I was wondering if it is worth replacing them on old motherboards, i.e, not with different ones but the same ones, like for like.
Apologies if this is a dumb question, I do not know much about electronic but I value some of my old boards quite a bit and if there is something that can be done to extend their life expectancy I'd love to know.
Reply 1 of 3, by kalohimal
If the failure rate is high then yeah, if not then just replace those that failed. Power on your board once a while and they will be ok, as tantalum caps could self heal when heated up during operation.
Slow down your CPU with CPUSPD for DOS retro gaming.
Reply 2 of 3, by chrismeyer6
It definitely couldn't hurt to replace them. The biggest thing with tants is watching polarity cause that'll make them shoot flames too
Reply 3 of 3, by Intel486dx33
I would recommend photographing the motherboard first. I heard stories about motherboard not always being labeled correctly.
