First post, by adalbert
Is there any possibility of modding such passive slotket (no voltage clamp chip) for Coppermine or Tualatin CPUs on dual CPU Via 694X board? It supports 100 and 133 FSB (Tyan s1834d), but I don't know what would be the I/O voltage there and if such slotket would work at all. In current state I only got some POST codes on diag card, but nothing on screen with overclocked Mendocino CPUs @ 100 fsb (there is no 66 option on M/B). Probably CPU just crashes right away due to overclock and possibly improper voltage. P3 coppermine doesn't work at all with that slotket. Slot 1 CPUs work fine, but i only have some low-end P2 and P3s, better stuff for slot is expensive. I wonder if I would be able to use such slotket with 1GHz P3 or 1.4GHz Tualatins. I remember modding M/B for coppermine cpu long time ago, I wonder if same hack would apply here.
