First post, by antrad
Do you remember when you upgraded to dual core computers and when did you first saw the benefit in gaming ? I guess this started around 2006-2007, I was stuck with a single core processor until 2014, so I missed the party.
https://antonior-software.blogspot.com
Reply 1 of 3, by leileilol
Quake3 did have SMP support back in 1999, but that's more for dual CPUs rather (NT4 was officially supported by Q3A). Quake 4 however did have early dual-core support in an early 2006 patch...
long live PCem
FUCK "AI"
Reply 2 of 3, by Kreshna Aryaguna Nurzaman
leileilol wrote on 2020-08-15, 05:22:
Actually, Falcon 4.0 beat Quake 3 to it.
Kreshna Aryaguna Nurzaman.
Reply 3 of 3, by DosFreak
Jan 2001 with Quake 3
2XP3-700E@933 133Mhz bus X 7 1/4
Abit VP6
Honestly though didn't enable SMP much in Q3, FPS were higher in at 800x600 and below but didn't game at low resolutions if I didn't have to.
I did see a benefit with everything on the system since it had dual processors so anything else running on the system didn't interfere while gaming even though the games were limited to a single processor which you could change the affinity for which was nice.
Played around with UT on a dual PPro 200 sometime in 2000 but AFAIK Unreal 1 didn't support SMP.
Next processor that had multiple core was in 5-18-2007 C2D E6600, even then barely any games used multiple cores. I seem to remember Supreme Commander having support. UE3 games? Farcry 1, Serious Sam 2.
You probably need to look at 2008+ for a larger list. Mabye track when the game engines started adding support, included Vista on the game box, XBOX 360 ports, etc.
Make your games work offline
