First post, by SVD
Hi, I hope someone can help me with getting the ROM for the CL-GD5464-HC-A.
I just bought 5 of these cards new/old stock without their EPROM's.
If i could breathe some life in them that would be awesome. I never really flashed a old video card like this, do you think its feasible to do a hot flash in another card? or is the best bet to get one of those EEPROM flashers?
I was thinking to get some EEPROM's on ebay, any type better or more suited than others?
Thanks bunches 😀
Reply 1 of 4, by GigAHerZ
Did you try to google for roms?
http://www.vgamuseum.info/index.php/cpu/item/ … gd5464-laguna3d
seems to have something.
I would use a proper EEPROM burner. TL866II is the popular one that i also have. One time investment, but you'll be covered pretty much for the lifetime for tens of thousands of chips.
A little about software engineering: https://byteaether.github.io/
Reply 2 of 4, by SVD
Yes i did, but i did not see the tiny bios button on that site until now x) Thanks for the hint.
A burner is probably the safest bet, thanks 😀
Reply 3 of 4, by Imperious
I can find this one only, not sure if correct or not but when You get a eeprom burner you can try.
Reply 4 of 4, by SVD
Thanks! Then i have another ROM to try 😀 Can there be large differences between the ROM's?
