First post, by Marcel VINCENT
Marcel VINCENT
Offline
Alkarion wrote on 2005-08-26, 08:17:Since Win98 is built on a genuine DOS you should be able to run CPBackup under Win98 or some MS-DOS mode.
Hi,
The CPBACKUP program only works with 386 PC, if you use the DMA access to the floppy disks.
You must have : an old 386 PC, and a release of CPBACKUP 4.0 for example.
Did you find any release of CPBACKUP ? And where please ?
Greetings
Marcel
