First post, by breadbin
I recently started messing around with my Pentium 3 again and decided to try and get a DOS 6.2 and Windows 98 dual boot but with Windows 2000 aswell so I can use the USB ports to transfer data. I made three partitions, 1.5GB FAT16 for DOS, 3GB FAT32 for Windows 98 and 3.5GB NTFS for Win2k. I installed DOS on the primary, then Windows 98, I wanted to put it on the next partition but it wouldn't let me. So it is in the FAT16 partition with DOS. Not ideal, but it works great so far. Then Win2K went on the last partition on NTFS. I edited the msdos.sys file so I have the boot menu for Win98 which allows me to boot DOS6.22. So now as it stands, I have access to each operating system from booting, it seems to run perfectly although I would prefer to have Windows 98 on the empty FAT32 partition. Is there a way to move it? Or even a way to tell it to install there in the first place?
The challenge I can see is that if I move it to the FAT32 partition manually the MBR won't see it and how do I change where it points to?
