First post, by jheronimus
Hi, all!
Got myself this Supermicro P54VL-PCI motherboard
It's a VLB Socket 5 board that I'd really like to use, but unfortunately it doesn't start. The best I could get is one long repeating beep and the POST card indicating some RAM issues.
The board came to me with a destroyed tantalum capacitor:
I've replaced the capacitor, installed a new CMOS battery. Here is what I've tried so far:
- different CPUs. 75, 90 and 100 MHz (the only ones officially supported) from Intel and AMD — 5 in total. Different jumper settings, too;
- different videocards: an S3 968 for PCI, a Tseng ET6000 for PCI, a Cirrus Logic GD-CL5428 for VLB and some Realtek for ISA;
- different power supplies;
- different RAM modules, both FPM and EDO (though the board should support both).
The board doesn't appear to be dead — there is a power LED on the board that gets green, the CPU gets hot, so does the VRM. The indicators on the keyboards flash for a moment on boot, but the keyboard doesn't react to keystrokes.
What else should I try?
Pentium 166 MMX Overdrive, 32 MB RAM, Ark Logic ARK1000VL, Tekram DC-680C, Turtle Beach Tropez, Gravis Ultrasound Max
Pentium III 1000, 256 MB RAM, Matrox G400 MAX, Adaptec 19160, Yamaha YMF740B
Reply 1 of 5, by luckybob
I have that board! It never worked right!
that said, just use some side-cuts to clip that tantalum. The board should post without it. My board is SUPER picky about memory. I'd suggest you keep trying with smaller simms.
Reply 2 of 5, by jheronimus
luckybob wrote on 2020-09-21, 21:02:
Tried 4x4MB of FPM RAM that I use on my 486 boards — didn't help. It still just gives one long beep. I should also say that the beep seems kind of muffled (I even tried two different PC speakers), but may be that's okay for an older AMI BIOS.
Reply 4 of 5, by jheronimus
Tried removing all of the cache, tried replacing all the chips, tried setting cache jumpers first to 256KB, then removed all the cache jumpers — nothing.
Actually went through all the jumpers using the TH99 page — set the IRQ3 (what is it for?) and video to Local bus (using the VLB card now).
Replaced the dead capacitor
The POST card reports D3 18 — I think it actually goes one step further now after I've replaced the capacitor, but I'm not entirely sure.
Reply 5 of 5, by jheronimus
Looks like it's a small Pentium+VLB boom on Vogons! I think I've seen two or three people mention they are working on such board or even starting a dedicated post for it.
I found a great guy on a Russian retro forum who managed to restore my board just in time for New Year:
Really a dream come true. I'm going to a NY party in a couple of hours, but in one or two days I hope to find time for a proper build.
I'm curious what kind of speed the VLB cards will run on, but I'm guessing it will either be a fixed 33MHz, or FSB clock/2 (so 33MHz for P100).
