First post, by Rehevkor
I have a vintage Packard Bell I'm using for DOS games. I installed an AWE64 (PnP), ran DIAGNOSE (all tests worked as expected), added AWEUTIL /S to autoexec, and confirmed that sound and music work perfectly in Duke3d. However, I can't seem to get music working at all in Doom. Whether I select General Midi or AWE32 (or any other music device) music will not play, only sound works.
Any suggestions? I'm a little new to configuring things like this in DOS so apologies if I'm just missing something obvious.
Edit: I fully power cycled the machine and now it works (???). At least I wasn't actually going crazy; it was set up correctly. Oh well.
I'll delete this post if necessary, but I thought I'd leave it in case someone else ran into the same scenario. No idea if the power cycle actually did something, but that's all I've got.
