E-Wave : an ESS based waveblaster card
Reply 81 of 125, by dreamblaster
Production batch of E-Wave ready and fully available now at https://www.serdashop.com/EWave
    878.61 KiB
Thanks for your support !
Reply 82 of 125, by matze79
Got final place for E-Wave 😉
1.72 MiB
Reply 84 of 125, by matze79
Yeah its Siemens PCD 5H from 1994 with Pentium 60 CPU, one of the early Pentium Machines.
Yes it has Hidden Artwork on the Mainboard 😉
Reply 85 of 125, by dreamblaster
A few more demos of E-Wave :
Descent - Level 1 : https://youtu.be/4Z36Tix2z6g
Sam and Max - The Scene Of The Crime : https://youtu.be/0ZW7eEGl5bA
Reply 87 of 125, by dreamblaster
mockingbird wrote on 2022-01-03, 17:26:
Hello sir,
I received my e-wave recently and I am enjoying it very much. Thank you.
Heart warming to hear, thanks!
Here are some more E-Wave demos :
Tie Fighter - Title Theme : https://youtu.be/8R05vd-P_b4
NCAA Road To The Final Four 2 - Menu Theme : https://youtu.be/9CWzFzEJnyA
Reply 88 of 125, by dreamblaster
A few more demos :
War Craft 2 - Orc Theme : https://youtu.be/w6xreQ7G7dI
Princess Maker 2 - Thanks : https://youtu.be/F5PWQUvnGGc
Sid & Al's incredible toons - Introducing Sid and Al : https://youtu.be/_lj4OZ2-OVQ
Reply 89 of 125, by Salient
Also made a demonstration video about the E-Wave daughterboard: https://www.youtube.com/watch?v=F9akzHFHPyw
Reply 90 of 125, by pan069
Salient wrote on 2022-02-27, 08:19:
Nice. Subscribed to your channel and bookmarked your website. Especially those articles (PDFs) of Computer!Totaal are a blast from the past.
Reply 94 of 125, by RetroGamer4Ever
pentiumspeed wrote on 2022-02-27, 18:54:
So that's similar to MT32?
Cheers,
No. MT-32 is not General MIDI. MT-32 uses Roland's proprietary MIDI format design and came before General MIDI.
Reply 95 of 125, by pentiumspeed
Thank you,
In order to play early games that uses MIDI, what is my options with current wavetable daughterboards that dreamblaster designed? Except for the McCake as it needs MT32 firmware which is extra expense to purchase.
Cheers,
Great Northern aka Canada.
Reply 96 of 125, by mkarcher
pentiumspeed wrote on 2022-02-27, 22:34:
The MT32 is a highly configurable sample-based synthesizer. Early games with more advanced MT32 output used the flexibility and programmed their own instruments based on the samples that are available inside the MT32. Those games will not sound correct unless the configuration is correctly interpreted. Up to now, that is only possible by using the original firmware (including the original samples), which is either expensive or illegal.
On the other hand, the MT32 came with 128 pre-configured instruments. If a game is only using these pre-configured instruments, a "MT32 soundbank" for a programmable synthesizer, or a synthesizer switchable to a "MT32 emulation mode" is likely good enough (there is a convention to have the MT32 default instruments on MIDI bank 127, possibly it's part of GS, thus it's a common way to enable MT32 emulation by sending a "switch to bank 127" command to an advanced MIDI synthesize). As the X2 has software-loadable sound banks, I'm very confident you can configure it to play back the default MT32 instruments, which will be good enough for a lot of MT32 games.
Reply 97 of 125, by dreamblaster
E-Wave review by Phils computerlab : https://youtu.be/lEo2o0cl3tM
Reply 98 of 125, by SuperDeadite
Super Street Fighter 2 on E-Wave.
E-Wave has some really strong bass. Fun match for sub-woofer users.
https://youtu.be/Vu4M5g_3CXg
Modules: CM-64, CM-500, SC-55MkII, SC-88 Pro, SY22, TG100, MU2000EX, PLG100-SG, PLG150-DR, PLG150-AN, SG01k, NS5R, GZ-50M, SN-U110-07, SN-U110-10, Pocket Studio 5, DreamBlaster S2, X2, McFly, E-Wave, QWave, CrystalBlaster C2, Yucatan FX, BeepBlaster
