First post, by Hanamichi
The card used to work fine. Had a few lockups in the system it was running in before I pulled the card.
Now part of the Xilinx Spartan 6 FPGA overheats straight away on boot and is burning the FPGA plastic like cover if left on for more then 10 seconds.
Just wondered if someone else ever had a silmilar issue.
Was lucky to find this one and a bit gutted if it's busted.
Tested with multiple known good PSUs, two motherboards.
Will post pics later, no damage visible or touching IC legs.
Reply 1 of 2, by The Serpent Rider
May indicate damage from static/short circuit.
Reply 2 of 2, by Hanamichi
I think you could be right, I remember getting static once when unplugging the card from a Radeon 9550 output. Although it kept working fine for sometime after.
I read some development boards with the Spartan 6 have had the same issue, reprogramming worked for them.
