First post, by PoulpSquad
- Member
Hello all,
I have an SC-55 connected to an UM-ONE and 2 virtual MIDI devices set up in loopMIDI.
DOSBox "sees" them all and can use them properly, but each time I remove the UM-ONE device, the order changes and I have to reconfigure my batch files to pair each game with its proper MIDI device.
I tried MIDIMapper from CoolSoft, but it is only a partial solution. It adds itself as device 0, and is only able to set a device as default.
Something I've noticed with loopMIDI is that MIDI ports don't get an ID in Windows. A quick look in HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Multimedia\MIDIMap reveals only the UM-ONE device is present.
I am trying to find a solution that would let assign an arbitrary ID to each device and if at all possible, get rid of that piece of garbage "Microsoft GS Wavetable Synth" (yes, I tried removing it from device manager by showing hidden devices, but it comes back after I reboot).
Any tips would be very welcome!
