First post, by Boohyaka
Hey, I started having that weird issue on my 486 yesterday and I can't wrap my head around it, probably missing something basic or obvious I'm afraid.
I use a UMC 8672 VLB based I/O card, and a serial Logitech mouse connected to one of its serial ports. In config.sys I'm loading UM8672.sys which gives me a great performance boost on connected hard-drives. I've been running that setup for a long time with no issue whatsoever.
Now the problem is, yesterday night Ctmouse started reporting not finding any mouse connected. Weird... After some trial and error, I noticed that skipping the 8672 driver, the mouse is detected fine (COM1/3f8h/IRQ4). The driver has a menu that is accessible by pressing F10 during boot, and in there, I can enable/disable serial ports, assign them to COM1/COM3 or COM2/COM4 respectively. COM1 is enabled, and correctly reports 3F8h in there as well.
So it's really weird. I'm toying with that config quite a lot so I'm not able to single out what could have changed. I believe it feels like an IRQ issue, but why would the driver make a difference, particularly when it's properly setting the COM1 with the proper parameters that Ctmouse detects when the driver is not loaded? As said it's quite a nice boost to performance so I'd rather keep using the driver, and I know it was working before.
Any idea or lead on stuff to check? Cheers
Reply 1 of 3, by Boohyaka
Apologies for bumping my own thread - this is turning me crazy and can't make any sense out of it, so again trying to find some knowledge with new information. Please help me for my own sanity! 😁
Here's what I done:
- I've removed everything but the IO and VGA cards
- I've reset BIOS to default
- I've started fresh from empty config.sys (only loading the IO driver) and a fresh autoexec.bat (only loading ctmouse)
- I've checked the jumpers on the IO card for Serial Config (no reason they changed but still)
- I've tried latest alpha from cutemouse, as well as latest stable
- I went crazy because it used to work fine and I can't figure out what changed, at this stage the only rational explanation is that it just randomly stopped working...which doesn't satisfy me
Here are a few screens:
BIOS screen showing COM ports as 3F8h and 2F8h
Driver NOT loaded - ctmouse detects mouse fine, and comtest shows proper COM ports and addresses. Why is it detecting a modem on COM2 is a mystery though, nothing is connected to COM2.
Driver NOT loaded - SysInfo shows proper COM1/IRQ4 used by ctmouse
Driver loaded - ctmouse finds no device and comtest shows nothing
Driver loaded - SysInfo shows COM ports normally and available...
Driver config screen showing COM ports enabled with the proper address...
I really hope someone comes up with an idea because I really want to keep using the driver.
I'll happily wager sending a fair amount of Swiss chocolate over to the one that finds the solution to that mystery, as a fun expression of my deep gratitude 😁 this still stands if it's just me being stupid and/or uneducated and hopefully I'll learn something new!
Reply 2 of 3, by jakethompson1
I believe when you mess around with that UM8672.SYS menu it creates a hidden configuration file directly under C:\. You may need to use with ATTRIB to see it, and make it so you can get to it. It may be best to delete that file and start over.
Reply 3 of 3, by Boohyaka
You're the man!
So yes indeed it creates a 13 bytes file called 863data in the root. What's funny is that that file is only created when going into the driver setup screen...and once the file exists, mouse fails.
If I delete it and never go in the config screen, it properly detects and sets my drive to fastest speed (which is basically the only reason I'm using it), the file doesn't get created and mouse works fine.
Sounds really weird to me but that's more than good enough for me - as long as my ports work and I still get the nice performance boost!
Fancy some chocolate? I'm dead serious 😁 I've wasted hours the past few days on that crap!
EDIT: checked my PM's and knew your name was familiar, you're the guy that shared his custom made driver to optimize performance 😉 looks like you know your UMC 8672 pretty well 🤣!
