First post, by NC Mountain Man
I am working on building a 486 PC and I am having trouble getting the motherboard to do anything at all. In an effort to troubleshoot what the problem is and leave as few variables as possible, I was wondering what is the minimum amount of hardware that needs to be installed on the motherboard. For example, should I get some sort of video on the screen with just the motherboard, processor, RAM , video card, and power supply? Is there anything else I need at a minimum such as a controller card, cache, hard drive, etc? I have gone over the jumpers over and over again, and I feel certain they are set correctly. Unfortunately, I do not have a spare video card to try. I would have to buy another one.
Below is a listing of the hardware I am using:
Motherboard: Aopen VI15g
Processor: Intel 486 100 Mhz (Also tried AMD 486 100)
RAM: 32 MB FPM (I have two sticks and I tried them individually and together)
Cache: 256K L2 Cache UM61256FK-15
Controller Card: VL-400GG Goldstar Prime 2 VLB Card
Video Card: VGA-542V Cirrus Logic GD5426 Chipset (Supposedly New Old Stock)
Power Supply: New Athena AT power supply (Checked voltages with a multimeter)
    1.97 MiB
Reply 1 of 13, by SodaSuccubus
Minimum hardware should just be CPU, RAM, Motherboard speaker and a VGA card. Try a simple 5V CPU like a DX33 if you have one.
Hell you probably don't need a video card if you have one of those POST display code cards.
Reply 2 of 13, by Deksor
Yes it should POST with a video card.
Is there any sign of life ? (error beeps, etc)
What happens if you remove the RAM stick, does it beep ?
Make sure your CPU is powered with 3.3V, it's a intel DX4, running it at 5V would kill it ...
You can find jumper settings over here http://www.win3x.org/uh19/motherboard/show/167
(feel free to send us a nice photo of your motherboard so we can add it 😁. Same deal with your BIOS if you get it to POST !)
Reply 3 of 13, by cyclone3d
Do you get beeps if the video card isn't installed?
You need a PC Speaker connected for beep codes of course.
Is the CMOS battery good?
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 4 of 13, by jakethompson1
I'm wondering what that Molex power connector suspiciously near the voltage regulator is for.
If you power it on does the cpu quickly get hot to the touch? Like within 10-15 seconds
If you indeed don't have a pc speaker connected, you don't know if it's not working at all or just beeping. Also, I've found when testing a VLB motherboard outside of the case, try wiggling the video card before you turn the power on as there is nothing to hold it firmly in place. You might also try the pencil eraser trick to clean the contacts on the video card.
Reply 5 of 13, by Baoran
If I remember correctly that is 5V only motherboard and you have put 3V cpu there. Also because of that the motherboard does not have jumpers to set cpu to dx4 ones. Perhaps you fried both of your dx4 cpus?
Reply 6 of 13, by cyclone3d
jakethompson1 wrote on 2020-10-08, 00:18:
According to the online diagram, that molex is for a case fan... But it is a female plug which indicates that it is for feeding power to the board.
YMF7x4 Guide
Reply 7 of 13, by NC Mountain Man
Thank you everyone for your input. I unfortunately do not have a PC speaker to hook up to the board at the moment, so I am not able to tell if it beeps or not. I have some of the small PC speakers and an ISA diagnostics board coming in the mail this weekend. The CMOS battery is new. This board is capable of using 3V processors . There is a voltage regulator beside of the processor and the voltages are changed using the jumpers. I previously had one of these motherboards with a DX4 processor in it.
Reply 8 of 13, by Horun
NC Mountain Man wrote on 2020-10-08, 20:27:
If you have an old pair of cheap (dollar tree type) headphones you can use one just strip the wires and solder a 4 pin header to either left or right side. Most of those cheap headphones are 32ohm and work very well as a cheap fix for a tester pc speaker....
Reply 9 of 13, by jakethompson1
And you've already tried cleaning the ISA and VLB contacts on the graphics card, and bumping it back and forth to make sure it's securely in the slot?
Reply 11 of 13, by Deksor
That molex connector is used to plug in the CPU fan.
When you take a look at CPU fans from that era you'll notice that they have a male and a female molex connector. Normally you use the female connector to connect it to the PSU, but with this kind of motherboard you use the male connector instead. It's great for cable management 😁
And no it's not used to power the mobo. I guess it shouldn't hurt it if you try, but I wouldn't recommend trying that anyways
Reply 12 of 13, by NC Mountain Man
I received the POST code analyzer card today and it gives it gives a couple pieces of information. First it includes a speaker. When i hook the speaker up the motherboard, it does not make any beeps during the start up process. When looking at the numerical post codes, sometimes it will show that #13 fails and sometimes it will show that #5 fails. Post code #13 has to do with "Early POST initialization of chipset registers". When it fails at #5 there seems to be another problem. The post code card will go through the codes up until #5 and then restart itself, and then do that over and over. It is almost like the motherboard keeps restarting itself. Post code #5 has to do with "Initializes the interrupt controlling hardware (generally PIC) and interrupt vector table".
    1.64 MiB
    1.52 MiB
