Windows XP+7 GPU
First post, by Velociraptor
Being an idiot I went and bought what I researched to be the best price/performance low cost, and most importantly the lowest energy consuming graphics card to use in my machine that's intended to cover Windows XP (and maybe Windows 7). I bought a 1050 ti which of course has no drivers for XP.
Previously I had a Quadro 2000.
The machine is intended for anything that's too much for my P2 system that comfortably runs on XP, plus it's also for modern remakes of stuff - things like Baldur's Gate Enhanced.
Am I right in thinking that while the Quadro 2000 may not be the most efficient card around, it's probably totally fine and I didn't need to "upgrade" to the 1050ti, or is there another card that can go in this that will suit the purpose better?
Reply 1 of 15, by darry
A GTX 750 TI might be a good option .
Reply 2 of 15, by infiniteclouds
I have a Titan Black which is a slightly better 780 ti (more RAM). I'd recommend either. I got my Titan Black last year for $150 used.
Reply 3 of 15, by darry
infiniteclouds wrote on 2020-10-12, 04:39:
Considering that the OP is aiming for, and I quote, "the lowest energy consuming graphics card", I doubt a card like this, with its 250W TDP, is what he would want .
A GTX 750 TI has a TDP of 60W and is still significantly faster than a Quadro 2000. See https://gpu.userbenchmark.com/Compare/Nvidia- … -Ti/m7708vs2187
Reply 4 of 15, by bloodem
I have a similar system (Core i5 3570K, 8 GB RAM DDR3, GeForce GTX 760). It's actually very good for dual booting Windows 7 + XP, however I think that the video card is a bit too new for older, classic XP gaming (newer drivers don't work properly with games such as Far Cry).
So I'm actually thinking about replacing the video card with a GTX 285. Another option that I'm considering is to build a separate Vista / XP system with the GTX285.
2 x PLCC-68 / 4 x PGA132 / 5 x Skt 3 / 1 x Skt 4 / 9 x Skt 7 / 12 x SS7 / 1 x Skt 8 / 14 x Slot 1 / 6 x Slot A
Current PC: Ryzen 7 9800X3D
Backup: Ryzen 7 5800X3D
Reply 5 of 15, by The Serpent Rider
I would suggest GTX 280, because you can voltmod it via BIOS.
Reply 6 of 15, by bloodem
Thanks, but in my case I already have a Gainward GTX 285 😀 Bought it some months ago for $10, but haven't had a chance to properly test it out, see which drivers have the best bang when it comes to performance/compatibility.
Reply 7 of 15, by Velociraptor
Thanks for the tips - looks like a 750ti is a good option - the 780 ti I don't think I'd use for 4:3 resolution games, I have a 1080 ti in my main PC with an ultrawide so I'm not looking for something as powerful.
https://www.techpowerup.com/review/asus-gtx-7 … 0-ti-oc/26.html
When that was tested it was more efficient that anything else around.
https://www.techpowerup.com/review/asus-gtx-9 … -matrix/24.html
Even a generation later it was still as efficient as it comes.
Having now looked into it a bit the 750ti is the smallest lithography I can get for Windows XP - this probably explains why it's the most energy efficient I'll find. Anything smaller is not directly supported on XP.
I do have another machine which runs DOS/Win98SE/XP and has an FX5500 in it so I hope anything that is not comfortable on the 750ti would be ok on that. But as usual with these types of things there will always be gaps.
Reply 8 of 15, by swaaye
Yeah remember the DX10 and later cards can't do any dithering at 16bit color so those games would look awful. And it certainly isn't going to bring you any fog table emulation for those DX5 games that use that. FX 5500 would have you covered.
DGVoodoo 1/2 should do Glide games well on a 750 Ti. Perhaps zeckensack's Glide wrapper too.
Reply 9 of 15, by The Serpent Rider
I would argue that that DX10+ cards are the best way to experience Glide emulation. Because, quite ironically, only DX10+ hardware is capable to replicate smooth texture filtering from good pre-DX7 era hardware like Voodoo 2-5, G400 or TNT.
Reply 10 of 15, by swaaye
Radeon 9500/9700, which lack trilinear optimization in hardware AFAIK, and the Radeon X1000 series set to HQ AF should be quite clean. X1000 HQ AF has actually been shown to be superior to the filtering of their DirectX 10/11 cards. But that Quake 3 sky might be more than just a texture filtering issue...
Reply 11 of 15, by leileilol
swaaye wrote on 2020-10-16, 05:58:
Q3's sky issue's more of a nVidia's "gold standard opengl" behavior of clamping was wrong all along and ATI is handling edge clamping properly as intended (for OpenGL behavior standards, not id's nvidia-as-reference).
long live PCem
FUCK "AI"
Reply 12 of 15, by The Serpent Rider
That's not just an issue with Quake 3, that particular sky texture or OpenGL. Obvious blockiness can be spotted in other places, like here on lightmaps in Unreal Tournament (D3D renderers). I think that it's not an issue with how mipmaps are sampled (which you are referring to), but with linear texture filtering itself. And that problem just "magically" disappeared on DX10 hardware.
Reply 13 of 15, by Almoststew1990
I don't know where you are in the world but I'll give a shout out to my GTX 645. Crucially it works on XP through to 10 just fine, still getting official 7/8/10 driver updates. Can download XP drivers using the normal Nvidia website.
It doesn't need a PCI-E power connector so is up to 75 watts of power.
It's a single slot cooler, which is quiet and is modern enough to spin up depending on load (this started at the 7900 series I think...)
It's comparable to a GTX 275 so plenty powerful enough for XP gaming and fine for Windows 7 gaming if you're doing less than 1080p. It will be lacking for new games, if this is going in your main PC.
It's about £20.
It's my most practical card!
Reply 14 of 15, by swaaye
I played with a lowly GT 730 (GK208 DDR3 edition) awhile back and it seemed to be as fast or faster than the X850 XT when I tried it with Dark Messiah. That is a wee tiny card. Lots of cheap but powerful options for old gaming.
Reply 15 of 15, by swaaye
The Serpent Rider wrote on 2020-10-16, 09:45:
Yeah I suppose it's reduced precision somewhere in the pipeline that is visible with the right conditions.
