First post, by Muz
Why is Warcraft 2 running fast when I upgrade my machine graphics card to Nvidia GT 710? The screen looks stutter when I run the game...
Too much power!!!
What is the alternative to solve this problem? Install the old graphic card in the second PCI slot? The game is Warcraft 2 BNE...
Muz wrote on 2020-10-27, 17:27:What is the alternative to solve this problem? Install the old graphic card in the second PCI slot? The game is Warcraft 2 BNE...
Still it will have enough power, why don't you limit the FPS or downclock the GPU
What kind of software to use to downclock the GPU?
Use period correct hardware 😉
I don't know what the problem is here, but considering this is one of the most popular games of all time, I'm sure there must be a solution out there that doesn't involve "period-correct hardware".
I suggest reviewing the GOG forum.
https://www.gog.com/forum/warcraft_ii_battlen … _help_requested
It looks like disabling vsync might help.
There's also a thread at https://www.nvidia.com/en-us/geforce/forums/g … games-might-be/ , but it's pretty old and might not apply anymore.
dr_st wrote on 2020-10-27, 17:21:Too much power!!!
A bit of Googling suggests the GT 710 appears to be a very underpowered card.
None of above helps, still stutter, I disabled V-sync, no luck...
Muz wrote on 2020-10-27, 22:58:What kind of software to use to downclock the GPU?
MSI Afterburner to downclock or to limit the FPS. If you are using the DOS version of the game, then there are many setting you could change, like change the renderer to OpenGL, then you could limit the FPS.
Discrete_BOB_058 wrote on 2020-10-28, 04:08:Muz wrote on 2020-10-27, 22:58:What kind of software to use to downclock the GPU?
The slide has to be in negative number?
Muz wrote on 2020-10-28, 04:30:Discrete_BOB_058 wrote on 2020-10-28, 04:08:Muz wrote on 2020-10-27, 22:58:What kind of software to use to downclock the GPU?
Yes, the core clock or the memory clock has to be negative.
If that doesn't help, then try DOSBox OpenGL thing I mentioned earlier.
I have played Warcraft 2 BNE on every machine imaginable, never had any stuter and speed issues. What version are you exacty using, what Windows version. Maybe using somekind of DDraw wrapper?
He might be talking about the map scrolling speed, which can be too fast on modern machines even on the slowest setting.
Try playing on a PC that can be slowed to 386 or 486/33 speeds, if not an actual such PC.
I changed from VGA to DVI cable, the game looks fine now...
jmarsh wrote on 2020-10-28, 07:01:He might be talking about the map scrolling speed, which can be too fast on modern machines even on the slowest setting.
kolderman wrote on 2020-10-28, 07:58:Try playing on a PC that can be slowed to 386 or 486/33 speeds, if not an actual such PC.
For the record, those would be problems with the original DOS version, not the 1999 Battle.net edition made for Windows.
Jorpho wrote on 2020-10-28, 14:38:For the record, those would be problems with the original DOS version, not the 1999 Battle.net edition made for Windows.
It's Muz. Treat all details as tentative at best.
I have another problem, DELL P2214H (the NVIDIA High Definition Audio), has no sound, but my Headphones (High Definition Audio Device) has a sound, but the sound stutter a bit when playing Warcraft 2 BNE. The screen and frame rate looks ok, but only the stutter sound problem now....
Muz wrote on 2020-10-28, 21:35:I have another problem, DELL P2214H (the NVIDIA High Definition Audio), has no sound, but my Headphones (High Definition Audio Device) has a sound, but the sound stutter a bit when playing Warcraft 2 BNE. The screen and frame rate looks ok, but only the stutter sound problem now....
Is there a PCI latency setting in the BIOS? If not, then you should be able to get a Windows based PCI latency utility.
Either way, try lowering the PCI latency to 32. Normal setting is usually 64.
