First post, by StarfireTBT
I am trying to get involved in other forms of emulation that require Dosbox. I already use Dosbox with a front-end program called Launchbox but it sounds like I also need Dosbox to emulate windows 3x games and mac games through Fusion PC 3.0.
Can one Dosbox be used in multiple programs or do I need multiple Dosbox's? I know there are config files can I just make copies and somehow tell other programs to look at different Dosbox config files?
Reply 1 of 1, by junglemontana
You can create multiple config files and start Dosbox with a specified config file using the command line.
