First post, by Guest
Guest
Offline
Hello ! I'm trying to play TieFighter under WinXP SP2 with WDMSound 2.04. But when I enable the Hires-Mode, I'm getting only a kind of stripes inside the inflight-mode. The hires-installation-menue is displayed correctly. And other Hires-Games (like Magic Carpet) seem to work. I tried with NoLFB in the beta 2.10 but with no success. I tried the UNIVBE of TieFighter, but it could not detect the chipset and brings no solution. Is it a problem with the graphic card ? I'm using an ATI 9800 Pro. Under Win2k with a Nvidia 2 GTS and an older version of VMDSound all is running fine.
Thanks in advance
Johann Letzel
