First post, by Akuma
Got nothing better to do today
So I started playing Rick Dangerous, man of Danger! 😴
After a daring attempt in level 2 I stumbled over my own fingers.
Needless to say, I found myself in the debugger again and discovered some really insignificant options. I checked the manual, and I could find nothing in there.
Drumroll πŸ₯
1. You can use E,C,T in the main menu instead of 1,2,3
2. You can use all the above options from the command line
eg:
"rick 1" or "rick e" will start rick directly in EGA mode
"rick 2" or "rick c" will start rick directly in CGA mode
"rick 3" or "rick t" will start rick directly in Tandy mode
I can't say I saved you a keypress as it actually adds one but hey "you can skip the menu" πŸ˜†
