First post, by matze79
Hi,
i have a 8800GTS with bended PCB,
any thoughts on bending it back ?
maybe i just put it beetween two books with the cooler removed ?
Whats the best way to bend it back without putting too much stress on the BGAs ?
The Card works but it looks really ugly with the end hanging down about 2cm..
Also the Power Cable Plugs in there which buts additional Stress on the PCB.
The Card has several Holes for mounting a Backplate and a bigger Cooler.
But Sparkle only used a 4 Point mounted one.
i had the idea to 3d print a rail and put it on the pcb edge to stabilize it.
Any Ideas for a good fix ?
Thanks
Matthias
Reply 1 of 2, by Nexxen
I wouldn't bend it back, as solder joints (points) could break and gift you with a lengthy reflowing session.
I'd leave it as it is and just find a way to stabilize it.
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
- "One hates the specialty unobtainium parts, the other laughs in greed listing them under a ridiculous price" - kotel studios
- Bare metal ist krieg.
Reply 2 of 2, by chrismeyer6
Would you mind posting pictures if the card?
