First post, by mpe
Looking for Windows 3.1 drives for the following card:
It is quite uncommon card. This one is ExpertColor DSP64300. Some other cards sharing the same chip include Boca Research Voyager and maybe more.
Anyone has them?
Blog|NexGen 586|S4
Reply 1 of 10, by matze79
Just uncommon on VLB Card, was used a Lot in Industrial Stuff and Mobile Computing Devices.
ftp://retronn.de/driver/Chips/
Reply 2 of 10, by The Serpent Rider
It's uncommon, but with decent performance.
Reply 3 of 10, by mpe
Thanks. Generic 1.0 drivers from the above site do seem to work. Although, 24bit isn't stable to complete my tests. 8/16bit work well.
The card showed indeed very nice performance. In DOS it matches high-end cards and trails only Bali32 (ARK1000PV card). In Windows performance is almost S3 864level. At least in 1024x768/256 mode which is nice consider the later is 64bit card. Hope I can 24bit driver working somehow.
I tried with and without the cache DRAM. The benefit is about 15%.
Blog|NexGen 586|S4
Reply 4 of 10, by matze79
Yes it also does bitblt
Reply 5 of 10, by ViscousFlow
Hi, is there a chance that anyone still has a copy of the driver? The FTP link isn't working for me. Thanks
Reply 6 of 10, by PC Hoarder Patrol
ViscousFlow wrote on 2026-11-07, 01:32:
Welcome to VOGONS 😀
Link works fine for me (IE11)...file attached below
The attachment C&T64300.zip is no longer available
Reply 7 of 10, by ViscousFlow
Thank you! Lifesaver
Reply 8 of 10, by ViscousFlow
I spoke too soon, looking at the file they are the same NT 4.0 drivers already available on TRW. I was hoping for 3.1 drivers to be out there somewhere, since the chip is of the correct time period
Reply 9 of 10, by PC Hoarder Patrol
ViscousFlow wrote on 2026-11-07, 05:53:
This one... https://vogonsdrivers.com/getfile.php?fileid= … 088&menustate=0
Reply 10 of 10, by ViscousFlow
Awesome! Somehow two different search engines couldn't pick this up for me... I appreciate the patience
