Internal Audio Help
First post, by Grayshazzle
Hello, so I linked the pictures below because I would like that cable to go to a spdif digital connection if possible, the picture with the holes on the cable is the one that goes into the pc header for the front aux and mic ports. I have no headers on my Audigy 2 ZS that will work with this cable so I didn't know what the name is of this cable is and if I could find a possible straight shot cable into a digital spdif. Thanks guys.
Reply 1 of 3, by chinny22
If you just want to use the case ports this is what you are after
http://audigy2zshowto.blogspot.com/2005/05/wa … stroy-your.html
As digital only supports stereo anyway (suck's I know) your best bet is a just to use the existing port on the back with a 3.5mm to RCA converter.
Reply 2 of 3, by Grayshazzle
chinny22 wrote on 2020-12-07, 12:49:
Thanks man! 👍
Reply 3 of 3, by gdjacobs
SPDIF supports compressed multichannel audio as well as stereo bitstreams.
