First post, by OpenRift
Been trying to do some TCP/IP experiments with DOSBox Optionals, but I can't connect to the internet because as far as I've read, there isn't a way to connect DOSBox's NE2000 emulation to Wifi, only Ethernet. That being said, is there a workaround for getting my wifi adapter to show up in the realnic list?
Reply 1 of 6, by Jorpho
You mean https://github.com/MartyShepard/DOSBox-Optionals ? I'm not familiar with that one.
What were you reading about NE2000 emulation?
If all else fails you could try running DOSBox in a virtual machine , which might provide more tolerant network hardware.
Reply 2 of 6, by _Rob
The NE2000 emulation uses PCAP in promiscuous mode, which does not work with WIFI adapters.
As Jorpho suggested, you could run DOSBox in a virtual machine and use that virtual machines virtual network to bridge to your wifi. But that probably means it only works for DOS applications needing TCP/IP.
Reply 3 of 6, by _Rob
Assuming you have an Ethernet port, but simply no nearby Ethernet cable nearby to plug into it, something like this may help: https://www.amazon.com/IOGEAR-Ethernet-2-WiFi … 7/dp/B018YPWORE
Disclaimer: I have never tried one of these devices.
Reply 4 of 6, by DosFreak
IIRC, the issue isn't winpcap but the wifi driver. It's possible if you hunt down the right wifi card and driver then you'd be good. Try investigating sniffer compatibility guides if you want to go down that route.
Make your games work offline
Reply 5 of 6, by Falcosoft
It's not impossible to use wifi card with (win)pcap and thus with NE2000 emulation of DosBox. As DosFreak has written this problem is entirely driver related. I have and old 802.11g SMCWPCI-G Wifi network card that works perfectly in DosBox with the generic Atheros driver but not with its specific SMC driver.
402.02 KiB
Website, Facebook, Youtube
VST Midi Driver Midi Mapper
Reply 6 of 6, by cyclone3d
_Rob wrote on 2020-12-08, 17:43:
That one is quite expensive. The Vonets ones are cheaper and work just fine:
https://www.amazon.com/Vonets-VAR11N-300-Mult … /dp/B01199OGK0/
There are a bunch of different models.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
