First post, by badmojo
- l33t
Hi!
I might be about to expose my ignorance here but I use a little app called 6x86opt to optimise my CPU Cyrix MII and with a Matrox Millennium I was able to use the -linbuf option to set up the LFB. This worked - the app found the address of my frame buffer and I got a couple of extra points in benchmarks.
I've recently switched to an Ark 2000MT based card - this thing also has a frame buffer I'm promised but 6x86opt can't find it. There's an option to specify the address of the buffer and the card's memory size but... how to I know what the address is? Neither this app nor another I tried are able to find it.
Any help much appreciated and if I'm talking nonsense then be gentle 😊
