First post, by Theodinator
Hi!
A few weeks ago I've bought this card for my Compaq Deskpro 2000 5200:
The attachment IMG_20201207_204509.jpg is no longer available
The attachment IMG_20201207_142612.jpg is no longer available
It was working fine alongside a Diamond Monster 3D PCI 4MB but recently the VGA BIOS only shows 2MB of RAM instead of 4MB:
The attachment IMG_20201215_085011.jpg is no longer available
In Windows 95 dxdiag detects the card as 2MB as well and I can no longer configure the same resolutions/color depth. I've tested the card in another computer but it's the same there.
This seems like a hardware defect.. Any ideas what has broken on the card? Maybe some bad capacitors?
Reply 1 of 1, by SSTV2
Had exact problem with a 8MB version of Elsa Erazor II card (TNT), the culprit was a damaged SMD resistor near one of the RAM ICs. RAM amount and RAM bus width were halved at that point, but card worked flawlessly, though slower.
If you can't find missing or damaged resistors on PCB, check RAM ICs for broken solder joints.
