First post, by robertmo
i have noticed that you no longer add supported commands to help listing. why? please continue adding them 😉 (you can use "hit any key to continue" cause they will take more than one screen)
(path command is not listed for example, i wonder if anything else...)
Reply 1 of 2, by Qbix
Rank DOSBox Author
DOSBox Author
we only list the ones we think that are important
as path is a shortcut for the set path command I didn't list it.
it's bool variable.
{       "CHDIR",        0,                      &DOS_Shell::CMD_CHDIR,          "SHELL_CMD_CHDIR_HELP"},
{ "CD", 1, &DOS_Shell::CMD_CHDIR, "SHELL_CMD_CHDIR_HELP"},
{ "CLS", 0, &DOS_Shell::CMD_CLS, "SHELL_CMD_CLS_HELP"},
{ "COPY", 0, &DOS_Shell::CMD_COPY, "SHELL_CMD_COPY_HELP"},
{ "DIR", 0, &DOS_Shell::CMD_DIR, "SHELL_CMD_DIR_HELP"},
{ "DEL", 1, &DOS_Shell::CMD_DELETE, "SHELL_CMD_DELETE_HELP"},
{ "DELETE", 0, &DOS_Shell::CMD_DELETE, "SHELL_CMD_DELETE_HELP"},
{ "ERASE", 1, &DOS_Shell::CMD_DELETE, "SHELL_CMD_DELETE_HELP"},
{ "ECHO", 0, &DOS_Shell::CMD_ECHO, "SHELL_CMD_ECHO_HELP"},
{ "EXIT", 0, &DOS_Shell::CMD_EXIT, "SHELL_CMD_EXIT_HELP"},
{ "HELP", 1, &DOS_Shell::CMD_HELP, "SHELL_CMD_HELP_HELP"},
{ "MKDIR", 0, &DOS_Shell::CMD_MKDIR, "SHELL_CMD_MKDIR_HELP"},
{ "MD", 1, &DOS_Shell::CMD_MKDIR, "SHELL_CMD_MKDIR_HELP"},
{ "RMDIR", 0, &DOS_Shell::CMD_RMDIR, "SHELL_CMD_RMDIR_HELP"},
{ "RD", 1, &DOS_Shell::CMD_RMDIR, "SHELL_CMD_RMDIR_HELP"},
{ "SET", 0, &DOS_Shell::CMD_SET, "SHELL_CMD_SET_HELP"},
{ "IF", 0, &DOS_Shell::CMD_IF, "SHELL_CMD_IF_HELP"},
{ "GOTO", 0, &DOS_Shell::CMD_GOTO, "SHELL_CMD_GOTO_HELP"},
{ "TYPE", 0, &DOS_Shell::CMD_TYPE, "SHELL_CMD_TYPE_HELP"},
{ "REM", 0, &DOS_Shell::CMD_REM, "SHELL_CMD_REM_HELP"},
{ "RENAME", 0, &DOS_Shell::CMD_RENAME, "SHELL_CMD_RENAME_HELP"},
{ "REN", 1, &DOS_Shell::CMD_RENAME, "SHELL_CMD_RENAME_HELP"},
{ "PAUSE", 0, &DOS_Shell::CMD_PAUSE, "SHELL_CMD_PAUSE_HELP"},
{ "CALL", 0, &DOS_Shell::CMD_CALL, "SHELL_CMD_CALL_HELP"},
{ "SUBST", 0, &DOS_Shell::CMD_SUBST, "SHELL_CMD_SUBST_HELP"},
{ "LOADHIGH", 0, &DOS_Shell::CMD_LOADHIGH, "SHELL_CMD_LOADHIGH_HELP"},
{ "LH", 1, &DOS_Shell::CMD_LOADHIGH, "SHELL_CMD_LOADHIGH_HELP"},
{ "CHOICE", 0, &DOS_Shell::CMD_CHOICE, "SHELL_CMD_CHOICE_HELP"},
{ "ATTRIB", 0, &DOS_Shell::CMD_ATTRIB, "SHELL_CMD_ATTRIB_HELP"},
{ "PATH", 1, &DOS_Shell::CMD_PATH, "SHELL_CMD_PATH_HELP"},
the 0 or 1 determines wether it's listed
Water flows down the stream
Reply 2 of 2, by icemann
Erm only the ones that are important? How are we supposed to know which commands work and dont work? Sounds kinda silly to me.
Surely it wouldn`t be that hard to type up a quick text file of available commands.
Two stones, two crosses, the rest is just icing. - 7th Guest
